Author Topic: Change element status after user change any element attribute  (Read 10066 times)
etaha
« on: January 30, 2018, 09:05:54 am »
Is there a way/event to change status of an element after user change any attribute of an element?
For example, if element status is approved I need to revert it back proposed in case user change element name/description/tagvalue etc..
Thanks in Advance.
Re: Change element status after user change any element attribute
« Reply #1 on: January 30, 2018, 09:50:14 am »
You need to write an add-in for that (or use Geert Bellekens' EA-Matic). There's a broadcast event which tells you that an element has changes and you can do further action.
etaha
« Reply #2 on: January 30, 2018, 07:01:17 pm »
Thanks a lot.
I've checked all broadcast events documentation amd EA-Matics available events; but I couldn't figure out which event to use.
There are events for pre-posting/deleting element but none for modify element.
Uffe
« Reply #3 on: January 30, 2018, 07:17:17 pm »
You're looking for EA_OnNotifyContextItemModified. It's in with the other context item events.
Note, however, that semantically this approach will only ever give you a partial solution. It doesn't cover all cases where something is changed which affects en element (eg inherited attributes).
/Uffe
etaha
« Reply #4 on: January 30, 2018, 07:21:12 pm »
I'll check that event; It's wierd that it's under contextmenu.
Thanks you all.
« Reply #5 on: January 30, 2018, 07:43:19 pm »
Hehe. EA is not only unique in its user interface but also in its documentation.  The people from planet Sparx have a different mindset than us common earthlings.
Uffe
« Reply #6 on: January 30, 2018, 10:19:09 pm »
It's not context menu -- it's context item.
The context item events tell you when the user has changed the selection in the GUI, double-clicked something or made changes to the currently selected thing (element, diagram, etc).
So they're GUI-related, but nothing to do with any menus.
/U
etaha
« Reply #7 on: January 31, 2018, 07:37:16 am »
Thanks for the note..and sorry I didn't notice it..
I've register that event with EA-Matic and it works, but there is an issue when user wants to change to Approve this will automatically revert to Proposed
function EA_OnNotifyContextItemModified(GUID, ot)
Dim el
If ot = EA.ObjectType.otRequirement then
    Set el = Repository.GetElementByGuid(GUID)
if el.Status = "Approved" then
el.Status = "Proposed"
el.Update()
end if
end if
end function
Is there a way to know the updated attributes of the element?
Thanks a lot.
Nabil
    • View My LinkedIn Profile Here
« Reply #8 on: January 31, 2018, 02:52:12 pm »
By default there is no method says which are the attributes got updated. You have to do a compare, then update . EA_OnNotifyContextItemModified will be triggered when current context item has been modified
« Last Edit: January 31, 2018, 04:37:06 pm by Nabil »
Nabil
etaha
« Reply #9 on: January 31, 2018, 03:12:20 pm »
Thanks for the reply..
As per my tests, this event is not triggered unless user clicks on Apply or Ok buttons, which is after the changes happened and no way to get element attributes' values before updated by this event only.
Any ideas?
Thanks in Advance...
Nabil
« Reply #10 on: January 31, 2018, 04:36:16 pm »
You have to get the previous values in session for a compare. When the user clicks next element/connector/diagram EA_OnContextItemChanged event will get triggered.
Nabil
etaha
« Reply #11 on: January 31, 2018, 06:16:26 pm »
Many thanks.. I'll try it out.
etaha
« Reply #12 on: February 01, 2018, 01:34:26 am »
Appreciated. Many thanks to all. It works.
