Author Topic: export attributes of a class  (Read 13563 times)
KNVB
« on: April 03, 2018, 07:00:55 pm »
Hello
I am using Enterprise Architect 13.5.
Would you tell me how can I export a class/element with the attributes name only?
thank you very much
Nizam
  • Prolab Moderator
  • Model Sharing - Simplified
Re: export attributes of a class
« Reply #1 on: April 03, 2018, 09:48:09 pm »
Print in Word / Excel?
Word - RTF Template
Excel - CSV Export or MDG Office integration
KNVB
« Reply #2 on: April 04, 2018, 04:59:02 pm »
Both of them are ok.
However, is it possible to export it as the following:
|        Class Name        |
|Attribute 1               |
|Attribute 2               |
|Attribute 3               |
|Attribute 4               |
|Attribute 5               |
Nizam
  • Prolab Moderator
« Reply #3 on: April 04, 2018, 08:58:45 pm »
Yes, sure it is possible, Try enabling <element> tag and <attributes> tag in the RTF editor and just enable names in each. EA will render the list as you've asked
KNVB
« Reply #4 on: April 06, 2018, 02:17:44 pm »
I can export the attributes of an element, however, I cannot export the class diagram as my specified format.
Would you tell me which attributes should I select when creating document template?
« Reply #5 on: April 06, 2018, 04:41:17 pm »
On the diagram properties dialog, go to the Features page and set "Show Attribute Detail" to "Name Only". You may also want to switch off "Show Qualifiers and Visibility Indicators" on the same page.
Nizam
  • Prolab Moderator
« Reply #6 on: April 06, 2018, 06:50:44 pm »
Image - https://www.dropbox.com/s/1i667wmv502m992/2018-04-06_1831.png
Key here is, just enable the 'diagram -> element' (don't add anything), but just fill the 'Elements'
Helmut Ortmann
« Reply #7 on: April 08, 2018, 07:22:55 pm »
one way to export something is to write/use a search/query and:
- Export results to *.csv and then to Excel
- Use the free hoTools to directly export the query results to Excel
  (see: https://github.com/Helmut-Ortmann/EnterpriseArchitect_hoTools/wiki/Export)
Best regards,
Helmut
KNVB
« Reply #8 on: April 10, 2018, 05:43:25 pm »
Sorry, I cannot find the diagram properties dialogue box.
Would you tell me how can I found it?
thank you
KNVB
« Reply #9 on: April 10, 2018, 05:58:19 pm »
It does not work.
I attached the screen dump and the generated document for your reference.
https://www.sendspace.com/file/zdilyo
« Reply #10 on: April 10, 2018, 06:29:44 pm »
Just dbl-click a free space on the diagram and the properties will open.
