Author Topic: Problem with Update method  (Read 20829 times)
cjcrystal
Re: Problem with Update method
« Reply #15 on: May 17, 2018, 07:41:58 pm »
in relation to Element.Update ,
How exactly does this work?
Updates the Element in the database and the model?
What happens when the Element is locked. Does it force Update?
Thank you.
« Reply #16 on: May 17, 2018, 08:43:44 pm »
Update save the changed properties of your EA.Element instance in memory to the database.
If the element is read-only because of locking you'll get an exception.
cjcrystal
« Reply #17 on: May 22, 2018, 02:20:50 pm »
thank you Geert  , much appreciated
bilon
« Reply #18 on: May 23, 2018, 10:05:02 pm »
Yes, this way it is described in the documentation: "Should be called after adding a new item or after deleting an item".
« Reply #19 on: May 23, 2018, 10:53:17 pm »
Most times the question is "what does the documentation not say?". So it does not tell that altered elements of the collection still are shown unaltered unless you re-fetch the whole element (and its collections) anew.
bilon
« Reply #20 on: July 25, 2018, 05:41:37 pm »
I've contacted sparx, they said it's an issue, it should be fixed sometimes :-) in the future.
