Author Topic: Automation Interface background  (Read 61471 times)
Dermot
« on: September 26, 2003, 12:33:09 am »
This is just to give some background information about the Automation Interface :
On the website there is a new set of pages with some example code/application for using the Automation Interface.  This is available from: http://www.sparxsystems.com.au/AutIntVB.htm
There is a set of documentation defining the use of the Automation Interface available in the Enterprise Architect Helpfiles which can be found under the Help | Help Contents | Automation and Scripting menu item in EA.
There is reference to this in HTML format in EA under Help | Online Resources | Automation Interface - this takes you to the online version (The direct address to this: http://www.sparxsystems.com.au/userdocs/AutoInterface/index.htm).
