Author Topic: How to change the "Notes" window background color?  (Read 9172 times)
purplex88
« on: May 21, 2018, 01:47:18 am »
I know it is possible to change the "Notes" window background color if I set a different theme.
It changes to completely white or gray depending on the Visual Theme e.g. Office 2000 or Visual Studio 2013.
Is it possible to manually tweak "Notes" window background color?
Can I customize the theme to change this color?
Re: How to change the "Notes" window background color?
« Reply #1 on: May 21, 2018, 02:11:01 am »
Yes,
Changing the color of a single note is done using the appearance options (bucket).
Creating your own theme is also possible.
Nizam
  • Prolab Moderator
  • Model Sharing - Simplified
« Reply #2 on: May 21, 2018, 10:15:50 am »
You can consider 'Template Package' to achieve this.
Takeshi K
    • Sparx Systems Japan
« Reply #3 on: May 21, 2018, 11:32:34 am »
I guess that purplex88 are not after Notes element but Notes dockable window.
AFAIK, we can not change background (and also default font) color of the window.
t-kouno
purplex88
« Reply #4 on: May 21, 2018, 04:28:03 pm »
Yes, you are right. I need to change color of "Notes" dockable window.
Can I edit a theme to do it? or any other way?
« Last Edit: May 21, 2018, 04:29:46 pm by purplex88 »
« Reply #5 on: May 21, 2018, 05:13:38 pm »
No, I don't think you can do that.
purplex88
« Reply #6 on: May 21, 2018, 06:05:45 pm »
I can change it if I use a different Visual Theme, so why I cannot I do via. editing a Theme?
« Reply #7 on: May 21, 2018, 06:58:28 pm »
Because there is no GUI for doing that. Maybe there's a file somewhere in EA's guts that can be altered. Or, maybe, there's some code in EA.exe that can be patched.
purplex88
« Reply #8 on: May 22, 2018, 01:54:02 am »
Yes,
Did you mean creating own Visual Theme? How? If so, then I can define my own theme colors for "Notes" dockable window.
RoyC
  • Read The Help!
« Reply #9 on: May 22, 2018, 12:02:31 pm »
No, I believe that Geert meant creating a diagram theme; that is, how a diagram and its contents are displayed.
Best Regards, Roy
