Author Topic: SPARX EA Enterprise does not start after last time  (Read 4464 times)
saugup05
« on: May 23, 2018, 06:40:12 am »
New to SPARX EA Enterprise...
Installed correctly, was able to start it a few days back but now it does not work.  I double click SPARX EA enterprise icon and it shows the logo in the middle of the screen and turns the pointer to loading pointer but after few seconds nothing happens.
I am curious if this has happened with other users as well or if there is any change required in Registry or some installation parameter...
Thank for your help
Sunshine
  • Its the results that count
Re: SPARX EA Enterprise does not start after last time
« Reply #1 on: May 23, 2018, 06:46:58 am »
Not had that problem but try repairing or re-installing.
Happy to help
saugup05
« Reply #2 on: May 23, 2018, 07:01:02 am »
just re-installed but again the same issue...
« Reply #3 on: May 23, 2018, 07:54:42 am »
Not much left than guessing. But if re-installation does not work it might be some strange security issue with Windoze (Registry).
« Reply #4 on: May 23, 2018, 11:40:32 am »
saugup05, I recommend contacting sparx support directly through the links below.
You'll need to include your EA build number and the OS version/build.
Sunshine
« Reply #5 on: May 24, 2018, 06:17:30 am »
@saugup05. Have you by chance upgraded to Windows 10 build 1803? I've noticed issues installing sparx ea as they've changed to the security. Found I need to disable folder protection. Search the forum to find the details on the fix.
Happy to help
