Author Topic: Where are quicklinks of an MDG stored in the database?  (Read 33224 times)
Re: Where are quicklinks of an MDG stored in the database?
« Reply #15 on: June 27, 2018, 03:23:07 pm »
Define Metamodel Constraints
The relationships you see in the ArchiMate technology are (mostly) the ones that are defined in the metamodel diagrams in the specification. Using this method allows you to define both quicklinkers and model validation using exactly the same information.
« Reply #16 on: June 27, 2018, 04:02:23 pm »
In v14 they made a change in the way the quicklinks are populated.
Before v14 you had to fill in a massive CSV file with every possible combination.
Now the quicklinks are apparently derived from the UML profile in some way.
I still have to dive into it myself but I would guess that this probably how the new quicklink works.
pieter.steyn
« Reply #17 on: June 29, 2018, 11:34:05 am »
Yep.
Got this response from support:
The ArchiMate 3 MDG technology in EA 14 is using the metamodel functionality introduced in EA 14 to define quicklinks.
http://www.sparxsystems.com/enterprise_architect_user_guide/14.0/modeling_tools/metamodelconstraints.html
This method is a little less flexible than defining quicklinker rules explicitly, but allows you to model the relationships instead, and is much simpler when you have a set of stereotypes with inheritance between them. It also has the advantage that the rules you define can also be used by model validation.
Thanks!
matthew.james
  • Am I supposed to say something here ... ?
« Reply #18 on: June 29, 2018, 12:23:23 pm »
So the Archimate MDG has been built using metamodel constraints, which drive the quicklinks ?
What about the 'model validation' mentioned above?  Is there a way I can validate a package for compliance to the MDG (ie Archimate) as opposed to base UML validation (using 'Validate Current Package')?
I started a post on this a few days ago if you'd rather use that to respond:
http://www.sparxsystems.com/forums/smf/index.php?topic=40041.0
« Reply #19 on: June 29, 2018, 03:21:39 pm »
I think Simon is talking about the strict connector syntax option here.
matthew.james
« Reply #20 on: June 29, 2018, 03:32:14 pm »
Leave me with my hopes and dreams for a little bit longer ...
It feels like the framework is there for 'proper' model validation and that it should be possible. Maybe ?
« Reply #21 on: July 02, 2018, 10:51:45 am »
The same rules that drive Strict Connector Syntax are checked during model validation. So it's both.
Having said that, I know that the rules defined for ArchiMate haven't been refined as much as I would like them to be.
matthew.james
« Reply #22 on: July 02, 2018, 01:08:39 pm »
So ... is there a way to do a package level model validation against a UML profile (as opposed the base UML validation which the "Validate Current Package" does) ? Specifically for Archimate ?
If so, how does one do that ... ?
« Reply #23 on: July 02, 2018, 03:50:10 pm »
What build of EA are you using?
Build 1422 validation reports validation errors in the same situations as strict connector syntax prevents.
matthew.james
« Reply #24 on: July 02, 2018, 04:53:15 pm »
Build 1420 ...
Strict connector syntax is working (mostly) as expected (there are some scenarios where I think it is valid Archimate but Sparx is saying no, need to dig into those bit further)
So - if I update to 1422 I get something different with validation ?  Can you describe / explain how it works ? (is it something I control through "Configure Validation Rules" ?)
