Author Topic: Connection not UML compliant (MDG - EA14)  (Read 15770 times)
Evandro
« on: July 25, 2018, 06:05:41 pm »
I'm reviewing a profile I created for an MDG technology (EA14). When I try to create a new stereotype that extends a new metaclass, I get the "requested connection is not UML compliant" message.
Any suggestion on why this happens, and how to fix it?
E
Nizam
  • Prolab Moderator
  • Model Sharing - Simplified
Re: Connection not UML compliant (MDG - EA14)
« Reply #1 on: July 25, 2018, 07:58:01 pm »
Haven't tested this, but there has been a number of reports related to 'strict connector syntax'  causing this issue. Try turning off strict connector syntax in preferences.
« Reply #2 on: July 26, 2018, 09:11:32 am »
Perhaps the requested connection is not UML compliant? ;)
What are the UML base metaclasses of your source and target elements and connector? Have you used the _metatype attribute in your profile to define your stereotypes as metatypes? Have you tried using the new <<metarelationship>> or <<stereotype relationship>> connectors to define your valid connections?
bknoth2
« Reply #3 on: January 24, 2020, 06:03:31 am »
Thanks for your insight, Nizam. "Strict connector syntax" was on in my preferences, and I couldn't even create this diagram: https://www.sparxsystems.com/enterprise_architect_user_guide/15.1/model_domains/interactionoverviewdiagram.html
EA 15.1 wouldn't let me connect "RequestItem" to the Ref below it.
Martin Kaul
« Reply #4 on: February 11, 2020, 01:10:28 am »
Same with other Connections:
- Diagram references linked with a Note element
- Assembly Connection between classes, or interfaces
I have already reported it to support on February 6 but so far no reaction, not even the reference to "Strict connector syntax"
« Reply #5 on: February 11, 2020, 01:24:15 am »
V14 won't be fixed anyway. Just if you were hoping for that :-/
