Author Topic: Project Integrity Check  (Read 4941 times)
ngong
« on: August 08, 2018, 03:28:20 am »
When I do a Project Integrity Check, I got one issue: The top-most package, the model itself, is flagged as "Orphaned object" and the check proposes the action "Delete Package Object". Obviously I do not follow that recommendation.
How to get a clean integrity check?
Rolf
Re: Project Integrity Check
« Reply #1 on: August 08, 2018, 05:58:41 am »
Report a bug.
Sunshine
  • Its the results that count
« Reply #2 on: August 08, 2018, 06:26:53 am »
Make a copy of your repository then let the project integrity check do its work. If you lose everything then do as qwerty recommends and report a bug. You never know it might actually fix your problem.
Happy to help
« Reply #3 on: August 08, 2018, 08:51:42 am »
Top level packages (root nodes) aren't meant to have a correspond object entry. While in your situation, I would back things up as already suggested. I expect that the action will only remove that object record, not the package or contents.
ngong
« Reply #4 on: August 09, 2018, 10:10:27 pm »
jepp - thank you all - worked fine
I did not understrand the problem - some LLEA... profile was in the way with an element called t_document - I never heard of before - but that is gone now and the entire model is ok (checked with LemmonTree against an older version).
Hence, seems not to be a bug to be reported to Sparx.
« Last Edit: August 09, 2018, 10:15:07 pm by ngong »
Rolf
EntArch123
« Reply #5 on: October 20, 2018, 01:42:55 am »
Please be very careful!! After performing a restore from a baseline then integrity checking this deleted all my previous Baselines! make sure you export all base lines to a local copy before performing this so you may restore them later! And make sure to have other methods of backing up data outside of EA.
ngong
« Reply #6 on: November 15, 2018, 07:45:31 am »
I am not using baselines for a big model, as it makes an eap file and any xmi export really large and unwieldy. I prefer to export as xmi and let our version control manage versions. It also has the benefit that I can create a baseline together with other documentation and source code.
Rolf
