Author Topic: Lock aspect ratio when resizing an image element  (Read 27744 times)
cryptology
« on: August 19, 2018, 11:05:17 pm »
I wonder if there is a straightforward way to lock the aspect ratio of an image element when resizing it. I've checked the manual but so far the only way I found to achieve this is by counting pixels in the status bar.
Re: Lock aspect ratio when resizing an image element
« Reply #1 on: August 20, 2018, 02:21:19 am »
AFAIK this can only be done in a shape script by setting fixedAspectRatio.
Takeshi K
    • Sparx Systems Japan
« Reply #2 on: August 20, 2018, 11:44:20 am »
If you are after a pasted image in diagrams, change its size with pressing SHIFT key.
It is the same as autoshapes in Excel, Word, etc.
t-kouno
Plonka
« Reply #3 on: December 18, 2024, 10:16:07 pm »
edit\
Well...found the solution.
I had some other commands befor "fixedAspectRatio = "true";".
In the Guide it is written that it should be befor drawing commands. Thats why it didn't work in the first place.
\edit
For Images pressing SHIFT works, thank you for that!
In shape script I can not make it work.
From the MDG Guide I assume that it should look like this:
shape main
       DrawNativeShape();
Am I right or is there something I got wrong.
Kind Regards
(I know I could open a new topic but I think it is usefull to have the solution here)
« Last Edit: December 18, 2024, 10:24:11 pm by Plonka »
