Author Topic: SOLVED:Retrieve All Elements On A Diagram  (Read 29678 times)
priombiswas89
Re: SOLVED:Retrieve All Elements On A Diagram
« Reply #15 on: December 15, 2020, 12:57:36 am »
Are you talking about selecting specific element or package, for example using the below documentation?
https://sparxsystems.com/enterprise_architect_user_guide/13.0/automation/objecttypeenum.html
« Reply #16 on: December 15, 2020, 01:02:37 am »
Yes, indeed.
That is a way to allow the user to select where to start.
If you are making an add-in you can add a context menu option to start your functionality.
Another option would be use to use the construct picker to let the user select an element.
priombiswas89
« Reply #17 on: December 15, 2020, 05:32:10 am »
Yes, indeed.
It is working with the following code, so far the package and element is working fine, except the diagram, I am trying to find a way to navigate to elements of diagram but so far haven't been succeeded:
                EA.Package pack;
                EA.Diagram diag;
                EA.Element ele;
                switch (Rep.GetContextItemType())
                    case EA.ObjectType.otPackage:
                            pack = Rep.GetContextObject();
                            EA.Collection elements = pack.Elements;
                            foreach (EA.Element element in elements)
                                if (element.Type != "Trigger")
                                    packageNames.Add($"{element.Type} : {element.Name}");
                                foreach (EA.Connector item in element.Connectors)
                                    int clientId = item.ClientID;
                                    int supplierId = item.SupplierID;
                                    EA.Element clientElement = Rep.GetElementByID(clientId);
                                    EA.Element supplierElement = Rep.GetElementByID(supplierId);
                                    packageNames.Add($" From : {clientElement.Name}\n To: {supplierElement.Name}\n Trigger: {item.TransitionEvent}\n Effect: {item.TransitionAction}");
                            break;
                    case EA.ObjectType.otDiagram:
                            diag = Rep.GetContextObject();
                            foreach (EA.Element element in diag.DiagramObjects)
                            break;
                    case EA.ObjectType.otElement:
                            ele = Rep.GetContextObject();
                            packageNames.Add($"{ele.Type} : {ele.Name}");
                            foreach (EA.Connector item in ele.Connectors)
                            break;
« Reply #18 on: December 15, 2020, 06:05:55 am »
foreach (EA.Element element in diag.DiagramObjects)This is where you are going wrong. There are no EA.Elements in the DiagramObjects collection, only EA.DiagramObjects (yes, sometimes it's that obvious, certainly not always though ;D)
Try
foreach (EA.DiagramObject diagramObject in diag.DiagramObjects)
