Author Topic: How to create Sub Category (infinity symbol)  (Read 5890 times)
vladap
« on: October 15, 2018, 11:33:24 pm »
Hi All,
I am little bit struggling with EA 14.  I would like to add to my diagram element (with infinity symbol) which is a hyperlink to other diagram. So if I click this element  It will open for me another diagram.
I was trying to drag and drop this diagram from Project browser menu - with the option Hyperlink, but it always insert for me just a text with small icon.
I am sure it was working in the past - but not sure if I am not skipping some step.
thank you for your advice.
Re: How to create Sub Category (infinity symbol)
« Reply #1 on: October 15, 2018, 11:44:20 pm »
In the old days it was via the context menu Add/Composite. No idea how/where that's located/hidden in newer versions.
« Reply #2 on: October 16, 2018, 02:25:48 am »
Are you sure the element you are referring to (the one with the infinity symbol, which is meant to represent three links of a chain) is a diagram element?
If you are seeing the link icon that usually a sign that it is a regular element that has been made composite.
You can see the actual type of the element if you select it in the diagram and press Alt-Enter.
That should open the element properties dialog.
To make an element "composite", right click on it on a diagram, and choose
New Child Diagram | Select Composite Diagram
vladap
« Reply #3 on: October 16, 2018, 02:36:50 am »
thanks, it worked
