Author Topic: Template- list Source & Target for Relations - only visible on the diagram  (Read 5059 times)
marku
I have diagram with relations between some elements ( from different packages)
Usually I'm doing "deep copy" to generated document with full informations- which I want
But its too complicated.
In Document Templates-> Sections is:
Package
           -Diagram
                         Connector
In this section <connector> are "Source Columns" and "Target Columns". But when I try generate document - this pool ale empty (In document I see name, Notes , etc about relations, but not Source & Target)
Of Course - I can copy it from window "Relationships" - and paste to word document - but why can't do it in Template?
marku
Any Idea?: "How to build template witch Source & Target for relations?
SourceColumns and TargetColumns is probably related to FK relations specifically, I'm not sure.
Anyway from the Diagram > Connector> you can't access the Source and Target Sections.
Only from Element > Connector>
marku
Geert - yes, it's only there
I'm thinking - Only I need this? :(
No you are not the only one.
I usually use an SQL fragment for things like that.
marku
Re: Template- list Source & Target for Relations - only visible on the diagram
« Reply #5 on: November 07, 2018, 01:41:43 am »
If someone want easy do it in Sparx - better way is do it in SQL
So, for what use by  SPARX? ;)
Thanks for answer
