Author Topic: connector visibility - what table in EA schema records the info ?  (Read 2860 times)
Amaurilo
I'm writing an application to retrieve info directly from EA's schema.
I need to discover what table is used to record the visibility status of a connector in a diagram.
Tried styleex on t_diagram with no sucess
Got the info on t_diagramlinks but the field "hidden" allways shows "0" despite the actual visibility condition.
Any help?
Regards
Amaurilo
Re: connector visibility - what table in EA schema records the info ?
« Reply #1 on: December 05, 2018, 05:29:58 am »
Just verified: it's in t_diagramlinks.hidden. If you test it, be sure to save the diagram after hiding a connector. Only the you have an entry in t_diagramlinks.
Amaurilo
« Reply #2 on: December 05, 2018, 06:54:01 am »
Thanks !!!!
saving the diagram did the trick.
