Author Topic: Automation Interface Installation  (Read 29310 times)
jmr
« on: December 15, 2003, 02:27:10 pm »
I just downloaded autintexe.zip, extracted the files into a directory, then launched setup to install.  During the install I get the following:
Install window stops with the following display:
Copying Files, please stand by.
Processing MSVBVM60.DLL (7 of 7)
Then, a Setup warning window opens with the following message:
Setup cannot continue because some system files are out of date on your system.  Click OK if you would like setup to update these files for you now.  You will need to restart Windows before you can run setup again.  Click cancel to exit setup without updating system files.
I have attemted to run setup 3 times, rebooting the system each time.  It's acting as though the last file is not being installed.
Has anyone else seen this problem?
Running Windows 2k SP4 with EA3.60 Bld655
