Author Topic: 2 stereotypes on attribute  (Read 14997 times)
The apprentice
« on: February 28, 2019, 02:22:27 am »
I use an Addins in C# and I would like add 2 stereotypes on attribute like this :
attribute.Stereotype = "New";
//attribute.Stereotype = "enum"; will erase the old value and I want just add it
Thank you
Re: 2 stereotypes on attribute
« Reply #1 on: February 28, 2019, 03:01:48 am »
use Attribute.StereotypeEx with comma separated stereotypes.
To be sure EA chooses the correct stereotype you can use fully qualified stereotypes (e.g. BPMN2.0::Activity)
The apprentice
« Reply #2 on: February 28, 2019, 03:52:44 am »
Thank you.
« Reply #3 on: February 28, 2019, 06:50:16 am »
Rather I think you should use FQNs. Even (especially) with those (barely documented) EAUML etc. profiles.
« Reply #4 on: February 28, 2019, 03:26:14 pm »
Yes, unless you are sure that your stereotype names are unique.
I tend to prefix all my own stereotypes with the name of the profile, so I'm 100% certain no other stereotypes exist with the same name.
Makes life a lot easier :D
The apprentice
« Reply #5 on: March 01, 2019, 01:27:19 am »
What's a FQN ?
I have 2 stereotypes now but I'm not sur about the methodology :
newAttribute.StereotypeEx = "University::New";
                    newAttribute.Update();
                    newAttribute.StereotypeEx = "University::Data";
                    //newAttribute.Stereotype = newAttribute.StereotypeEx;
It seems to be working but I don't know how to remove an attribute.
I also seen that from an EA Administrator :
Use StereotypeEx for every time you want to write a stereotype.
•Use HasStereotype() for every time you want to check a stereotype.
•Edge cases for appending a stereotype to the existing list or checking for any stereotype both use StereotypeEx.
•FQStereotype is read only. It allows you to see the profile the first stereotype applied comes from.
•MetaType allows you to get the Metatype defined for an applied stereotype. (It's not read only, but it ignores any assignment)
•SynchTaggedValues() should be automatic when assigning a stereotype. It's useful if the stereotype definition has been updated or tags accidentally deleted
Do I Use Stereotype ?
Thank You
Pardon my english
« Reply #6 on: March 01, 2019, 01:42:16 am »
FQN == Fully Qualified Name. So "University::New" instead of "New"
I think you can add both stereotypes at the same time by doing
newAttribute.StereotypeEx = "University::New,University::Data";
No, as you have read, the best practice is to not use the Stereotype property.
The apprentice
« Reply #7 on: March 01, 2019, 01:46:57 am »
Ok
But if I want to remove one of them. It'is possible to "clear" the stereotypeEx ?
« Reply #8 on: March 01, 2019, 01:49:23 am »
Ok
I'm pretty sure it's possible but I don't remember how exactly. You'll have to experiment a bit to figure out how to use it.
« Reply #9 on: March 01, 2019, 06:53:36 am »
Makes me think that this should be added to my Scripting book. How and when are which stereotypes affected  (passing null, single, list FQN, non-FQN) using stereotype and -Ex properties.
Richard Freggi
« Reply #10 on: March 01, 2019, 03:24:54 pm »
Per UML 2.5 can an element have more than one stereotype?  Asking for a friend.
« Reply #11 on: March 01, 2019, 05:19:55 pm »
Technically the only UML elements that have stereotypes are Profiles.
Setting a stereotype on an element is actually creating an instance of that stereotype and setting the base_Element property on the stereotype to that element.
Yes. It is valid to have multiple stereotype instances reference the one UML element.
Talking about EA instead of UML. EA also allows a stereotype to be used as a metaclass. The meaning of that is that the element is now an instance of a specialized version of the base type. Multiples of that sort of stereotype are more complicated conceptually, but generally in EA it will behave like only one has that property.
« Reply #12 on: March 01, 2019, 07:33:32 pm »
When applying a stereotype is equivalent to creating an instance, then how would that be possible with multiple stereotypes? Really sounds like we have a machine that creates zombies or mutants. Looking at how stereotypes are dealt with in EA this proves to be true.
Richard Freggi
« Reply #13 on: March 01, 2019, 08:31:53 pm »
Eve and Qwerty, thank you and I look forward to learning more if anyone has further insights
« Reply #14 on: March 02, 2019, 12:19:30 am »
My view on stereotypes always was rather EA-centric and I did not look too deeply into the UML specs (they are no good read anyway). However, I started reading now and see that stereotype is no property of element. Rather a profile defines a view on the model and it contains stereotypes to create extended elements based on UML elements (or such provided by other profiles). So assigning a (EA) stereotype as a property appears to be just wrong. Let alone assigning two stereotypes. From what I currently understand (which is honestly just a bit of the whole thing) EA's implementation just looks like a mess. Just what it always felt when dealing with stereotype property assignments over the last (10) years. It seems that EA tries to create an instance of the profile element on the fly when assigning a stereotype. No wonder I had this Frankenstein-feeling all time.
If I'm wrong I'm open to any lecture.
