Author Topic: Problem With Style Sheets  (Read 3397 times)
namealreadytaken
« on: March 01, 2019, 04:45:44 am »
Greetings,
Presently using EA v12 and having issues with updating templates based on style sheets.
I created a new sheet (TestStyleSheet), based on a system sheet (Print Large - Black). Make obvious changes. Increase Heading 1 to 72 and Dark Green.
Go to any template, right-click in the white space select File>Update Styles>TestStyleSheet.
No change whatsoever.
Am I missing a step?
Re: Problem With Style Sheets
« Reply #1 on: March 01, 2019, 05:31:57 am »
Are you sure you actually edited the style correctly?
Does it work in the stylesheet itself?
Editing styles is somewhat of a dark art in EA 8)
namealreadytaken
« Reply #2 on: March 01, 2019, 06:47:31 am »
Hi Geert,
The style sheet updates accordingly. Since the respective template does not update the style, I am assuming the modified styles would apply if I select the the sheet when generating the document.
Dark art is quite accurate.
