Author Topic: [Deployment] Repositories showing status as “PCS Connection Failed”  (Read 44535 times)
Prolaborate Support
  • Prolab Moderator
    • Visit us
This status shows up when Prolaborate could not establish a connection with the configured Enterprise Architect (EA) Model.
It could be because of the following reasons:
  • Either database configuration in Pro Cloud Server (PCS) is incorrect or the details of the EA database entered in Prolaborate are incorrect. Check whether you are able to connect to the EA model using Cloud Connection of EA with the same details entered in Prolaborate
  • The port used by PCS (For example, 804) is not open. From a browser in a local machine, enter the server name or DNS or IP address of the server where PCS is installed appended by the port number (For example, SSN007:804) and check whether you are getting a Congratulatory message.
  • Pro Features are not enabled in PCS
  • "Allow saving password" setting is not enabled while configuring the database managed in PCS
  • PCS OSLC Support is not enabled. Open PCS configuration file (Sample path: C:\Program Files (x86)\Sparx Systems\Cloud Services\Service\SSProCloud.config) and check if OSLC_Support is set to 1. If not, change the value to 1.
  • EA database is configured using User DSN. Configure EA database using System DSN if your EA models are on MySQL, Oracle, or Postgres
  • Sparx Systems Professional Cloud service is not running
  • OSLC support is not working fine. Check whether the following calls are working from the server where Pro Cloud Server is installed:
    • localhost:[PCS port]/[PCS Database Manager alias]/oslc/am/pbstructure/
    • localhost:[PCS port]/[PCS Database Manager alias]/oslc/am/sp/
    PCS port is 804 by default. The alias can be found in the PCS console.
Restart the "Sparx Systems Professional Cloud" service if you make any changes to the config file.
« Last Edit: June 05, 2020, 03:47:48 pm by Prolaborate Support »
