Author Topic: User Template - Requirements in table  (Read 5439 times)
Maciou
« on: April 16, 2019, 07:44:11 pm »
I use template selector for different elements in my documentation e.g. Requirements, Use Cases
And I want to have my Requirements in a table looking like this:
NameNotesModified
Requirement 1This is my first requirement11:38:00 16.04.2019
Requirement 2This is my second requirement11:39:00 16.04.2019
i try it with:
package >
element >
Name //as plain textNotes  //as plain textModified  //as plain text
Name //as field from right button context menuNotes  //as field from right button context menuModified  //as field from right button context menu
< element
< package
but it repeats heading for every requirement (i know that's this template is a loop for every element such as requirement).
How can i handle with this problem?
ps. i can't use Specification Manager List template or any other because this have to be inside one document with another contents.
Re: User Template - Requirements in table
« Reply #1 on: April 21, 2019, 02:52:01 pm »
There's an option in the table options to indicate it has a header row.
This will avoid duplication of that first row.
Maciou
« Reply #2 on: June 10, 2019, 11:17:54 pm »
Ok, I have realized that this probably works in template, but doesn't work in Fragments...
Is there any way to fix this?
« Reply #3 on: June 11, 2019, 12:23:47 am »
It does work in fragments. I use that all the time.
Maciou
« Reply #4 on: June 11, 2019, 10:42:37 pm »
I belive you, but this faith doesn't help me.
Is there any way to export template into XML to check what happens?
« Last Edit: June 11, 2019, 10:49:51 pm by Maciou »
« Reply #5 on: June 11, 2019, 11:05:42 pm »
Yes, that looks exactly like the templates I make.
Yes, you can export a template to xml with the option Configure | Transfer | Export reference data
Sometimes when stuff like this doesn't work I start over with a new template, and it suddenly works. Might be worth a try.
Maciou
« Reply #6 on: June 11, 2019, 11:17:01 pm »
Ok, new template works the same way... so it doesn't work.
XML gave me nothing.
Whole table is in base64...
I stucked...
Maciou
« Reply #7 on: June 12, 2019, 04:05:45 pm »
@Geert, maybe you can create and export for me such template fragment?
1 table,
2 rows (first as a header), 3 columns
and that's all
you can mail me at [email protected]
« Reply #8 on: June 12, 2019, 04:39:07 pm »
Hi Maciou,
I could, but then we would first need to agree on a price.
Unfortunately I can't work for free; need to feed the kids etc.. :D
If you are serious about this please email me at [email protected]
