Author Topic: Diagram strip Arrow controls need rework  (Read 14320 times)
« on: May 08, 2019, 10:10:48 am »
The diagram strip (in V14+) is now in a much larger font and some there are fewer visible on the strip than previously.  I don't have a problem with the font, but the arrows at the end of the strip seem to move only one character at a time.
<rhetorical question>
Can anyone supply the rationale for 1 character at a time, rather than the complete diagram name at a time?
</rhetorical question>
Should it be fixed, or am I alone in this?
Re: Diagram strip Arrow controls need rework
« Reply #1 on: May 08, 2019, 01:38:25 pm »
Whoever designed that control (not at Sparx Systems) intended those buttons to behave like scroll bar arrows. Hold them down to continuously scroll.
PS. Visual Style | Main View Tabs use Caption Style.
« Reply #2 on: May 08, 2019, 02:13:29 pm »
That also sucks (for me).  Try picking up the diagram name on a bouncing bus as it flashes past below.  That's why I posted.  I guess I'm too used to the Microsoft Access Window tabs or the NotePad++ window tabs or the Excel Window tabs etc. etc. which move a whole tab at a time.
A quick survey of a few products revealed that they either contract the tabs (with ellipses) when the set of tabs in the window overflows the size or they behave as I noted above.  None behave as EA.  Perhaps it's the wrong control?
Perhaps, the wrong
« Reply #3 on: May 08, 2019, 04:15:33 pm »
Another life-saver is the Ctrl-Tab
If you hold the Ctrl you can Tab through all opened diagram while EA gives you a preview of each diagram.
Turns out few people now about this feature; it's one of the things I use to WOW people  8)
Pretty sure it works better on a bumpy bus-ride than trying to click the little navigation arrows
« Reply #4 on: May 08, 2019, 05:37:28 pm »
WOW!
Thanks, Geert!
Sure would!
« Reply #5 on: May 08, 2019, 05:53:35 pm »
Uhm, what? Where and how do I need to hold the ctrl-key? And which EA version? Doesn't seem to work for me.
« Reply #6 on: May 08, 2019, 06:03:31 pm »
All versions that I know of.
Press and hold the ctrl key and then use tab or shift-tab to go through the open diagrams.
Should look like this:
https://imgur.com/lPVV7qS
« Reply #7 on: May 08, 2019, 07:14:19 pm »
No dice. Might be because I'm running Parallels on a Mac? Though these keys should be mapped correctly :-/
« Reply #8 on: May 08, 2019, 07:46:18 pm »
Might be. It doesn't work correctly when working via Remote Apps either.
« Reply #9 on: May 09, 2019, 04:40:11 pm »
Worked OK for me with Remote Desktop.
timoc
« Reply #10 on: May 09, 2019, 05:00:45 pm »
Works with crossover too - works with right and left control keys.
Tim,
« Reply #11 on: May 09, 2019, 05:37:34 pm »
Tim,
What keyboard does have a right control key?
timoc
« Reply #12 on: May 09, 2019, 06:42:19 pm »
Tim,
Dell KB 522:https://tweakers.net/pricewatch/365392/dell-kb522-(qwerty-us).html
« Reply #13 on: May 09, 2019, 08:00:54 pm »
Well, I'm working 99.9% of my time on a laptop. And 99.999% it's a Mac :-)
« Reply #14 on: May 10, 2019, 01:54:59 am »
Yes, for me too, but not when only the application is published (so you don't get a full remote desktop but only the one application)
Must be a remote desktop thing I guess.
