Author Topic: Automation Error  (Read 24966 times)
watchdogtimer
Automation Error
« on: January 12, 2004, 04:00:35 pm »
I am receiving an error trying to add an element to a package by using a TextStream in VB.
the following error is generated when I run e.Update to update the element
Run-time error '-2147417851 (80010105)':
Automation error
The server threw and exception
The code that breaks is:
       Set ts = fso.OpenTextFile(Text1)
       ts.ReadLine
       s = Split(ts.ReadLine, ",")
       Set e = Package.Elements.AddNew(s(1), s(3))
       e.Update
       Package.Update
The code that works that does not use a textStream is:
       Set e = Package.Elements.AddNew("new req", "Requirement")
       e.Update
       Package.Update
If there some limitation in the Automation Interface that does not allow using a text stream?
