Author Topic: Information flow conveyed items support  (Read 66510 times)
Guillaume
    • www.umlchannel.com
« on: August 12, 2019, 07:23:07 pm »
I defined flows between archimate application components to identify the data flows between applications.
On each archimate flow, I have Archimate Data Objects selected as info flows or conveyed items.
Opening the connector properties in Prolaborate, this information is not available.
Could it be supported in the future? And if so, could charts be updated accordingly e.g. in the new 3.2 Landscape chart, it would be useful to display the list of data objects conveyed on a flow between 2 applications.
Note: I found a workaround with the landscape chart using SQL Queries
« Last Edit: August 12, 2019, 11:17:48 pm by Guillaume »
Guillaume
Prolaborate Support
  • Prolab Moderator
    • Visit us
Re: Information flow conveyed items support
« Reply #1 on: October 24, 2019, 05:40:36 pm »
Hello Guillaume
Thanks for the suggestion. We added this item to our product backlog and will keep you updated when we take it up. Here is the Prolaborate link for your reference:
https://team.prolaborate.com/7Q5g60
Glassboy
« Reply #2 on: October 25, 2019, 09:17:13 am »
Conveyed items would be an underlying UML feature, not part of the ArchiMate notation.  It would be lost in an export in an ArchiMate exchange file.
« Reply #3 on: October 25, 2019, 09:25:42 am »
Have you checked?  It would be interesting either way.
If it's not exported, then stop asking - It's Bl**dy annoying having to dismiss the dialog!  If it is, then ????.
Glassboy
« Reply #4 on: November 04, 2019, 08:30:13 am »
I can't be bothered creating a model and going through the motions.  You can check the standard tho' https://publications.opengroup.org/c174
« Reply #5 on: November 04, 2019, 09:09:43 am »
You mean you have a "day job" that involves actually using Sparx EA to try and do real work?  (That's irony, )
Glassboy
« Reply #6 on: November 05, 2019, 08:58:14 am »
Calling it real work might be going too far.
« Reply #7 on: November 05, 2019, 10:22:09 am »
Touché!   ;D
Guillaume
« Reply #8 on: November 05, 2019, 10:05:01 pm »
IMHO this is only an issue if you have other tools to exchange your Archimate models. I found the conveyed items really useful to define flows between Application Components by linking Data Objects.
Guillaume
Glassboy
« Reply #9 on: November 06, 2019, 07:55:55 am »
I don't use ArchiMate for this, as it's a bit shit.  I use UML and Information Items which in turn map to class diagrams (conceptual and logical data models).
