Author Topic: v15 – Generalization Set Dialog, Doesn’t “SELECT DISTINCT”  (Read 2867 times)
This isn't so much a bug as an observation.  Should you accidentally have more than one Generalization between two items, the Generalization Set dialog doesn't do a "SELECT DISTINCT" so there will be two (or more if you're really sloppy) entries in the list.
This can happen in an enterprise-wide repository where the left hand doesn't know what the right hand is doing...
