Author Topic: xpath contains & starts-with method not recognized with JScript  (Read 6293 times)
Guillaume
    • www.umlchannel.com
I have a script that updates elements in EA from an input XML file.
I loaded the XML content using a "MSXML2.DOMDocument" activex in JScript and I need to loop through nodes which name attribute starts with "test".
I tried the following XPath expressions (tested ok with Notepad++ XPath Eval):
  • * var nodeList = xmlDOM.documentElement.selectNodes("//MyElement[contains(@name,'test')]");
  • * var nodeList = xmlDOM.documentElement.selectNodes("//MyElement[starts-with(@name,'test')]");
-> both return an "unknown method" error when executing the script
note: the following works ok in EA to fetch indivual entries.
var nodeList = xmlDOM.documentElement.selectNodes("//MyElement[@name='test1']");
var nodeList = xmlDOM.documentElement.selectNodes("//MyElement[@name='test2']");
Guillaume
Re: xpath contains & starts-with method not recognized with JScript
« Reply #1 on: August 30, 2019, 07:09:40 pm »
Have you tried with CreateObject("MSXML2.DOMDocument.6.0")
I believe the MSXML2.DOMDocument is an older version of the same library.
Guillaume
« Reply #2 on: August 30, 2019, 07:39:39 pm »
It works!  ;D
Many thanks Geert
Guillaume
