Author Topic: "Delete or Keep the bound properties" pop-up when running script  (Read 15612 times)
sar2
« on: September 04, 2019, 08:37:42 pm »
I wrote a script, which has quite some long running time and does sometime need to delete out dated elements.
Sometimes when I use the Delete(short index) method on a element object, I get a "Delete or Keep the bound properties" pop-up in the background, which causes my script to pause until someone closes that window. This is quite bothersome.
I already tried deleting all connectors of the element in question first, but that didn't solve the problem.
Anyone have a workaround this?
Re: "Delete or Keep the bound properties" pop-up when running script
« Reply #1 on: September 04, 2019, 08:40:41 pm »
I have never seen such a popup.
Could it be that you are deleting elements who have embedded elements?
In that case you might want to delete those first.
« Reply #2 on: September 04, 2019, 09:16:48 pm »
Also never saw that. Which EA version?
sar2
« Reply #3 on: September 04, 2019, 09:18:28 pm »
I'm using version 12.1
sar2
« Reply #4 on: September 04, 2019, 09:21:20 pm »
I try deleting connectors, embedded elements and constraints before the element and get the pop-ups during connector deletion all the time.
« Reply #5 on: September 04, 2019, 09:38:00 pm »
Ah, is it during a connector delete, or an element delete.
I think the bound properties are those things you set to link your association to an attribute.
I've never used those.
I would check if any of the collection on the connector (such as CustomProperties) has elements and make sure to delete these before deleting the connector.
PS. You should also report a bug. An API is not supposed to show message boxes when deleting stuff.
sar2
« Reply #6 on: September 04, 2019, 11:31:20 pm »
Ok so I tried deleting CustomProperties, but I get an Internal Application error.
I tried deleting all other collections as well, but it didn't help.
