Author Topic: Why doesn't the conjugated notation show up on a conjugated port?  (Read 5143 times)
mse
I have set a port property to conjugated, and I do not see the tilda (~) showing up next to the label. However, on the same diagram, with a different port, also with the same setting, the tilda does appear. Is there some other setting influencing this behavior?
mse
Re: Why doesn't the conjugated notation show up on a conjugated port?
« Reply #1 on: September 05, 2019, 08:54:16 pm »
Seems that removing the <<proxy>> stereotype from the port allows the tilda to display. However, I thought in SysML one chooses between full and proxy ports. Yes, leaving it empty is also acceptable, but I wanted to be explicit on my decision.
« Reply #2 on: September 06, 2019, 08:03:29 am »
Seems that removing the <<proxy>> stereotype from the port allows the tilde to display. However, I thought in SysML one chooses between full and proxy ports. Yes, leaving it empty is also acceptable, but I wanted to be explicit on my decision.
It may just be a shapescript bug.  Report it.
