Author Topic: Information Engineering Crow's feet  (Read 5702 times)
rupertkiwi
« on: September 09, 2019, 11:21:08 am »
Hi there,
I am trying to display a diagram in EA using the Information Engineering notation in a similar way to Erwin i.e. crow's feet. I can't seem to get this working however.
Does anyone know how to do this ans what type of diagram should I use?
Rupert
RoyC
  • Read The Help!
Re: Information Engineering Crow's feet
« Reply #1 on: September 09, 2019, 11:30:13 am »
Right click on the diagram background and select the 'Properties' option, then click on the 'Connectors' tab. In the 'Connector_Notation' field click on the drop down arrow and select 'Information Engineering'.
Does that help? You can set this on diagrams of any type. I believe.
Best Regards, Roy
« Reply #2 on: September 09, 2019, 11:32:56 am »
Hi there,
I am trying to display a diagram in EA using the Information Engineering notation in a similar way to Erwin i.e. crow's feet. I can't seem to get this working, however.
Rupert
Hi Rupert,
As Roy says, it is ALSO a function of the Diagram Connector display mechanism.  <context Menu> | Properties | Connectors | Connector Notation.  But in addition, there may be shape scripts involved which override the diagram notation.  For example, in our technology, ALL (simple) associations are represented as "crows-feet" and so our shapescripts explicitly draw them regardless of the diagram type.
rupertkiwi
« Reply #3 on: September 09, 2019, 01:57:11 pm »
OK, thanks for your replies
