Author Topic: Updating Normal.rtf when using an RDBMS repository  (Read 6772 times)
Re: Updating Normal.rtf when using an RDBMS repository
« Reply #1 on: March 24, 2020, 07:27:05 am »
Works just the same, but with more recent versions you can use the better Stylesheet option, see https://sparxsystems.com/enterprise_architect_user_guide/15.1/model_publishing/rtfdialogoptions.html
Modesto Vega
« Reply #2 on: March 26, 2020, 02:36:25 am »
Thanks skiwi, the reason for the question is that it "does not appear to work in v13" - emphasis intentionally added. I'll check the 15.1 stylesheets.
« Reply #3 on: March 26, 2020, 06:40:38 am »
I guess make sure that the template is in
%APPDATA%\Sparx Systems\EA\RTF Templates\
[/size][/color]
[/size][/color]
All I can say is that the document generation has continued to improve through the EA versions.
[/size][/color]
But having said that I still find issus with styles being applied, I suspect because Word doesn't "get" the styles generated by EA where there are multiple model documents each with its documnet template each (re)defining word styles.
[/size][/color]
[/size][/color]
Plus to be frank I've struggled to get the Stylesheet option to work the way I expect it to - which is to simply replace (override) the styles it defines across the entire document.
Sunshine
  • Its the results that count
« Reply #4 on: March 26, 2020, 01:03:46 pm »
I've managed to get the styles working just fine with stylesheets. You just have to change the style in style sheet and not just the text illustrating the style which is a common mistake.
I can send you an example if you like or after the lock down we could meet up for coffee and I can walk you through it.
Happy to help
« Reply #5 on: March 26, 2020, 03:30:06 pm »
I've done a lot of document generation in version 12, and there the stylesheet works mostly.
The only issue I found was the "normal" style. That one didn't behave, so I don't use that anymore and created my own MyNormal style.
« Reply #6 on: March 26, 2020, 04:42:42 pm »
That's been true of Word itself for decades.  The first thing one does is create one's own "Normal" style and base everything on that.
