Author Topic: Display attributes / tags on diagram  (Read 6655 times)
vladap
« on: March 09, 2020, 10:28:06 pm »
Dear EA Gurus,
I am dealing with a request of my colleagues, that they need to see Attributes or Tags next to the element in the diagram.
Is it possible to place this information directly on the diagram ?
Of course these information is changing quite often , so it should be dynamic and change accordingly.
thanks,
Vladimír
Re: Display attributes / tags on diagram
« Reply #1 on: March 09, 2020, 10:59:15 pm »
Depends. You can use on-board EA switches from the diagram properties/Elements. Alternatively you can place notes on the diagram and link them to elements. On the context menu of the note link you find Link to Element Feature which offers a couple of possibilities. Finally, if you have stereotyped elements you can use shape scripts to define what shall be shown. That's the most flexible way but needs a bit of overhead work.
vladap
« Reply #2 on: March 10, 2020, 12:18:53 am »
I am not sure if I understand you correctly. Here is the use case:
I would like to see in the note, the TAG Value .
« Reply #3 on: March 10, 2020, 01:33:21 am »
You need to open the context menu of the note link.
Uffe
« Reply #4 on: March 10, 2020, 01:42:13 am »
... Link this Note to an Element feature -- Single Tag and Notes    or   Attribute.
/U
vladap
« Reply #5 on: March 10, 2020, 02:59:14 am »
I don´t see it guys. Can you post a screenshot with this option?
« Reply #7 on: March 10, 2020, 05:21:04 am »
Strange they don't show a screenshot of the context menu and use a lengthy scenario description instead. Probably becase the UI changes faster than one could document it :-/
vladap
« Reply #8 on: March 10, 2020, 11:45:54 pm »
Ok, thanks. I found it now. For tag values it works nicely. I can display one or more Tags in the note.
For Attributes I found only options to show one specific atribute and not more.
« Reply #9 on: March 11, 2020, 12:37:50 am »
Attributes can be shown in the element compartment itself. Use Features/Visbility. You can also show (all) tags here and with Custom you can show individual attributes.
