Author Topic: RTF Generation with Relationship Matrix  (Read 4965 times)
kimberly
« on: October 17, 2012, 06:35:05 am »
I have used the relationship matrix to generate several DoDAF views.  I used the method in the example of creating a Matrix profile and then placing a hyperlink in a diagram to that profile.
I am trying to generate a report that pulls in these relationship matrices.  I have included the "Relationship Matrix" in the report template (selecting the checkbox in the editor).  And I have also tried pulling in specific attributes, like the Name, but I don't see anything in the report.
How do I incorporate the matrices into a report?
Thanks!  Kimberly
Konrad Wieland
Re: RTF Generation with Relationship Matrix
« Reply #1 on: October 18, 2012, 12:09:45 am »
As you described, you can include a matrix in the rtf generator by activating the checkbox. However, if you generate a documentation for a specific package, this package has to be used as source or target in the matrix.
Cheers,
Konrad
kimberly
« Reply #2 on: October 18, 2012, 12:16:52 am »
Sorry, I don't understand what that means.
Maybe more context will help.  When I generate the SV-5 I'm generating the matrix to show the system functionality to operational activity.  There isn't a package involved in that matrix.  To generate the documentation, I need to be able to pull the SV-5 out of EA.
How do I pull the matrix into a document?  The only thing I have on the "diagram" is the hyperlink to the matrix (I did this based upon the DoDAF example supplied with the template).  And I don't see an option to follow the hyperlink, the only option seems to be to select the Relationship Matrix in the RTF generator.
Thanks again for your help!  Kimberly
Stefan Bolleininger
« Reply #3 on: October 18, 2012, 04:40:31 am »
The matrix can be created by the report generator.
For that, it has to be designed into the template with the "template designer". That's, where the checkbox can be found.
I suppose the "template designer" is within the tab "Settings".
Regards
Stefan
kimberly
« Reply #4 on: October 18, 2012, 05:10:42 am »
My apologies, I don't know where the tab "settings" is located.
I know where Sections can be selected:
Project > Documentation > RTF Report (or F8)
Select my custom template in Use Template:
Then select Edit Template.
In the Template viewer I see Sections on the lefthand side, I put a checkmark next to the Relationship Matrix, under the Package group.  I looked at the tabs under the "Document Options" didn't see a "Settings" option thanks for any clarification!
Konrad Wieland
« Reply #5 on: October 19, 2012, 10:45:40 pm »
As you wrote, a relationship matrix is embedded under a package inside the rtf generator. Thus, this package must play a role, as source or target, in the matrix.
When you open the matrix builder you find top left two buttons for selecting source and target.
