Author Topic: Azure Platform Icon Set  (Read 10980 times)
« on: April 14, 2020, 05:59:23 pm »
Am I going senile or did I recently see a post asking about whether EA had (or was going to have) an Azure Platform Icon Set - similar to the AWS and GCP sets?
TIA,
Re: Azure Platform Icon Set
« Reply #1 on: April 14, 2020, 07:30:47 pm »
No, I can confirm. (or maybe we are going senile together)
But I can't find it quickly when I do a search.
« Reply #2 on: April 14, 2020, 09:56:49 pm »
That's why I asked, I searched and couldn't find it either.
Uffe
« Reply #3 on: April 14, 2020, 10:24:53 pm »
Well, define "recent", but I found two threads with OnT discussions.
https://www.sparxsystems.com/forums/smf/index.php/topic,42290.msg254390.html
and
https://www.sparxsystems.com/forums/smf/index.php/topic,43349.msg256897.html (last post a week ago)
But no official word beyond "it's being considered," which, well.
Anyway.
« Reply #4 on: April 15, 2020, 07:41:15 am »
In my opinion there is sufficient demand for it.
Back when we released the support for the two icon sets we have I used a combination of scripting and manual processing to import their icons into EA. I hope support still knows where they can get the resulting XMI. It may now be outdated and isn't as polished as the officially supported variety but it should help.
PS. I suspect I didn't think the process I used would need to be reproduced and that I didn't document it in any meaningful way. From memory, a linux script to convert all of the svg files to png with a consistent size, drop each directory of files onto an EA diagram as artifacts. EA script to remove the extension from the resulting object names.
« Reply #5 on: April 15, 2020, 08:21:23 am »
and
Anyway.
Turns out to be a "bug" in the search function (surprise, surprise).  Like you, I "knew" we'd had a post within the last week, so I set the search target to 99 days.  (Conserving electrons, my bit for global warming).  No "hit".  Extend to the default, 9999 days, many hits.
To me, that's a bug, .
When I search for posts, in a specific time frame, I'm searching for posts, not threads.  I suspect, that only the thread start date is used for the date filtering.
Roy and Eve, can you confirm or deny?
PS: At least, Geert and I aren't going senile yet!!
« Last Edit: April 15, 2020, 08:24:02 am by Paolo F Cantoni »
« Reply #6 on: April 15, 2020, 12:57:46 pm »
In my opinion, there is sufficient demand for it.
[SNIP]
How do we turn your opinion into a set of icons for us to use?  ;)
I have some users "champing at the bit" to use Azure icons.
« Reply #7 on: April 16, 2020, 08:50:53 am »
In terms of the behavior of this forum I know no more than you. Apart from occasionally deleting spam I'm just a normal user.
For the azure icons the best thing you can do is send a request to support. I don't know how much it will take to tip it into being a development priority.
« Reply #8 on: April 16, 2020, 09:22:01 am »
In terms of the behavior of this forum, I know no more than you. Apart from occasionally deleting spam, I'm just a normal user.
For the azure icons, the best thing you can do is send a request to support. I don't know how much it will take to tip it into being a development priority.
Done!
Fellow users - as Eve suggests, if we don't ask, we won't get!  Put in your requests!
Sunshine
  • Its the results that count
« Reply #9 on: April 17, 2020, 07:16:40 am »
I did the same as Eve back in 2019 and imported the Azure symbols into Sparx EA by dragging them into a diagram and running a script to fix the image names.
You can find the original model and the Azure Symbols MDG.xml file on GitHub.
https://github.com/EASunshine/Sparx-EA
Just treat the Azure Symbols MDG.xml file like any other MDG file. Put it in a folder and point Sparx EA to it. The Azure Symbols will then be available to use via alternative image mechanism.
Hope that does the trick for now.
« Last Edit: April 17, 2020, 07:26:33 am by Sunshine »
Happy to help
« Reply #10 on: April 17, 2020, 07:58:41 am »
Fantastic - thanks for all the hard work to pull that together
« Reply #11 on: April 17, 2020, 10:38:08 am »
For anyone who wants to use an updated set, or use a different resolution etc. Here is the (linux) command that I used to create pngs that can be dropped onto EA.
find -name *.svg | sed -E "s/\.\/(.*)\/([^\/]*)\.svg/mkdir -p \"png\/\1\" \&\& inkscape -e \"png\/\1\/\2.png\" -D -w 64 \"\1\/\2.svg\"/" | bash
If you're wanting to add them into the image manager instead of a structured model of image artifacts you can skip the child directories.
find -name *.svg | sed -E "s/\.\/(.*)\/([^\/]*)\.svg/inkscape -e \"png\/\2.png\" -D -w 64 \"\1\/\2.svg\"/" | bash
Sunshine
« Reply #12 on: April 17, 2020, 01:18:38 pm »
You're welcome.
Karma points welcome too
Happy to help
« Reply #13 on: April 17, 2020, 01:42:22 pm »
Tell me about it
Sunshine
« Reply #14 on: April 18, 2020, 07:11:56 am »
Tell me about it
Just click on the "helpful" link to the left of this post :)
Happy to help
