Author Topic: MDG Association direction mismatched behaviour for 2 users  (Read 5685 times)
Guillaume
    • www.umlchannel.com
I have an Archimate MDG with a stereotyped association that can be created from a stereotyped Archimate Node to a stereotyped Application Component.
In the stereotyped association definition, I set the default direction to be unspecified.
I set metaconstraints and quicklinker rules (using the new relationships) so users can only create such association from the Node to the Application
When I created the association from the Application to the node, or vice versa, the association is properly set from the Node to the Application with the Direction set to unspecified. The issue I have is that a user has the exact same EAP file with the same EA build (1528), and when he creates the association from the Component to the Node, the direction is set to Source to Target (from Node to Component, he gets the unspecified direction as expected).
I tried to look at EA Preferences (links) but they match.
I can't figure out why we don't have the same behaviour.
Guillaume
Re: MDG Association direction mismatched behaviour for 2 users
« Reply #1 on: May 20, 2020, 08:49:32 pm »
Any difference in the add-ins they are running?
I think one of these EA-Matic link style scripts I wrote used to mess up the direction somehow.
Guillaume
« Reply #2 on: May 20, 2020, 11:41:41 pm »
My client doesn't have any addin installed and I don't have eaMatic currently enabled on mine.
Guillaume
« Reply #3 on: May 21, 2020, 02:07:41 am »
The deployed MDG might be different. Check what is in the MDG path and what is imported in the ressources.
Sunshine
  • Its the results that count
« Reply #4 on: May 21, 2020, 03:09:05 pm »
I once had a user that copied the custom ArchiMate mdg file I'd created from a shared location to a private one and then pointed their Sparx EA to that. Needless to say when I updated it to enhance and fix things they didn't get the same as everyone else then complained about it. They soon shut up when I said they had caused the problem themselves through their own stupidity.
As Forrest Gump's Mama used to say;
Stupid is as stupid does.
Definitely worth checking what Qwerty says.
« Last Edit: May 21, 2020, 03:14:14 pm by Sunshine »
Happy to help
« Reply #5 on: May 21, 2020, 05:01:51 pm »
That's funny, I thought she said: "Stoopid is as stoopid ders"    ;)
