Author Topic: Import MDG into model automatically  (Read 20388 times)
« on: May 29, 2020, 05:09:36 pm »
I've been doing some work automating some of the stuff I do with UML profiles and MDG's
I now have a little script that generates my profiles, and then also generates the MDG technology; so far so good.
Now the next step is to import that MDG file into my model, and it looks like they thought of that as well. I found the operation Repository.ImportTechnology, which takes an xml string as parameter.
But when I tried that, it didn't overwrite my existing model MDG as I expected, it created a new MDG in the model in a way I couldn't do manually.
Underneath the MDG in the resources window I saw a package for patterns, a package for profiles, and one for code engineering, and in the "manage MDG technologies" the location of the MDG was not "model", but "project"
The documentation does mention something that it is related to pre-version 7 technologies, so maybe this is some very old forgotten relic from ye olde days?
Anyways, I'm still looking for a way to import an MDG file into a model with a script. Anyone happen to know if that is possible (and if so, how)?
Uffe
Re: Import MDG into model automatically
« Reply #1 on: May 29, 2020, 06:56:52 pm »
Oh snap! You too? :)
Pretty sure it is.
Well I haven't tried it, but an imported technology is placed in t_document with:
  • DocName = Technology ID
  • DocID = Don't know. A GUID which isn't in the technology .mts or .xml file.
  • ElementID = "TECHNOLOGY"
  • ElementType = "TECHNOLOGY"
  • DocType = "TECHNOLOGY"
... plus presumably the actual data in BinContent, but I haven't checked. All other columns show up as empty in EA's query results.
t_document is generally safe to insert into, isn't it? I mean, you don't have to perform any t_xref black magic right?
In which case a simple Repository.Execute() ought to do it.
/Uffe
« Reply #2 on: May 29, 2020, 08:32:21 pm »
Yeah, maybe one day I'll hack something together using Repository.Execute.
For now I'll guess I'll just have to import the MDG manually.
davor
« Reply #3 on: September 20, 2024, 11:46:00 pm »
Could you share the script (example) or point to relevant docs?
« Reply #4 on: September 21, 2024, 12:29:46 am »
'[path=\Framework\Tools\UML Profile]
'[group=UML Profile]
option explicit
!INC Local Scripts.EAConstants-VBScript
!INC Wrappers.Include
' Script Name: Generate EAM profiles and MDG
' Author: Geert Bellekens
' Purpose: Generate the EAM profiles and MDG
' Date: 2020-05-18
const outPutName = "Generate EAM"
sub main
'create output tab
Repository.CreateOutputTab outPutName
Repository.ClearOutput outPutName
Repository.EnsureOutputVisible outPutName
'map O: drive
dim shell
set shell = CreateObject ("WScript.Shell")
shell.run "cmd.exe /C subst o: c:\odrive", 0, true
'set timestamp
Repository.WriteOutput outPutName, now() & " Starting generate EAM MDG", 0
'Generate profiles
Repository.WriteOutput outPutName, now() & " Generating profile for 'EAM UML profile'", 0
Repository.SavePackageAsUMLProfile "{C259CE5D-901F-4eed-94D8-C760B306F6E8}", "" 'EAM UML profile
Repository.WriteOutput outPutName, now() & " Generating profile for 'EAM Diagram profile'", 0
Repository.SaveDiagramAsUMLProfile "{BA8F0EA9-9029-42b1-807B-EEBB636DB9C1}", "" 'EAM Diagram profile
Repository.WriteOutput outPutName, now() & " Generating profile for 'EAM Toolbox profile'", 0
Repository.SaveDiagramAsUMLProfile "{CD1D434A-60DC-4611-ACE4-ADB0A33F1D78}", "" 'EAM Toolbox profile
Repository.WriteOutput outPutName, now() & " Generating profile for 'OS Toolbox profile'", 0
Repository.SaveDiagramAsUMLProfile "{DCAC2032-24D0-4d7b-A99A-6E0B68C284F1}", "" 'OS Toolbox profile
Repository.WriteOutput outPutName, now() & " Generating profile for 'Change Management UML profile'", 0
Repository.SavePackageAsUMLProfile "{6657AC40-D2B2-4862-90E5-9327CDB6FFA0}", "" 'Change Management UML profile
Repository.WriteOutput outPutName, now() & " Generating profile for 'Change Management Diagram profile'", 0
Repository.SavePackageAsUMLProfile "{1A2CC264-B4EF-47db-8DAF-DAF9F992E5D9}", "" 'Change Management Diagram profile
Repository.WriteOutput outPutName, now() & " Generating profile for 'Change Management toolbox profile'", 0
Repository.SaveDiagramAsUMLProfile "{B0288241-37B7-4f50-9763-94974FA92497}", "" 'Change Management toolbox profile
'Generate MDG
Repository.WriteOutput outPutName, now() & " Generating EAM MDG technology", 0
Repository.GenerateMDGTechnology "O:\Sparx\MDG\EAM MDG.mts"
'set timestamp
Repository.WriteOutput outPutName, now() & " Finished generate EAM MDG", 0
end sub
main
davor
« Reply #5 on: September 24, 2024, 09:30:24 pm »
Thank you very much!
