Author Topic: Extending an existing MDG  (Read 3312 times)
GrahamL
« on: June 03, 2020, 08:07:27 pm »
Hi
I have a MDG from a third party in xml format.
Is it possible to load this into EA and extend it?
Re: Extending an existing MDG
« Reply #1 on: June 03, 2020, 08:37:10 pm »
No. You can create your MDG using external stereotypes manually, though.
« Reply #2 on: June 03, 2020, 08:47:59 pm »
I think you actually can.
You can redefine existing stereotypes, and add your own tagged values and stuff.
Just have to make sure you set your MDG as "Active" so it knows your MDG trumps the existing MDG.
See https://sparxsystems.com/enterprise_architect_user_guide/15.1/modeling/redefine_ster_other_prof.html
Uffe
« Reply #3 on: June 05, 2020, 09:18:18 pm »
Hi Graham,
As Geert mentions you can extend or redefine stereotypes in another MDG Technology, but you can't reverse-engineer one back into a set of models.
If you really need to reverse-engineer an existing technology it isn't actually impossibly hard to do -- depending on the technology's complexity -- but it can get you into murky waters wrt intellectual property.
/Uffe
