Author Topic: Add Ins: Status "Error-Missing"  (Read 58880 times)
zalbina
« on: October 16, 2012, 08:13:07 pm »
I've registerd my dll and created key successfully, but when EA starts in "Manage Add-Ins" the Status of it is "Error - Missing". I tried to do the same on different computes, but get the same result. I checked everything, but did not find the problem.
Thanks.
zalbina
Re: Add Ins: Status "Error-Missing"
« Reply #1 on: October 16, 2012, 08:37:08 pm »
Forgot to mention that I'm running the application (VS) as administrator. And after distribution of my dll on other computers I've the same issue "Error-Missing".
Thanks.
« Reply #2 on: October 16, 2012, 09:29:34 pm »
Haven't we discussed that issue already?
zalbina
« Reply #3 on: October 16, 2012, 10:01:03 pm »
We did, but it did not work out anyway :(.
« Reply #4 on: October 16, 2012, 10:32:38 pm »
Try calling one of the operations EA will call  (EAsomething()) from an excel VBA macro. If that works then the registration of your dll was successful.
zalbina
« Reply #5 on: October 16, 2012, 11:55:49 pm »
But how can it help to work with my ea addins? I'll try this.
« Reply #6 on: October 17, 2012, 12:02:35 am »
You want to know where the problem is right?
If you can call your dll from Excel VBA then the COM Interop registration is not the problem.
zalbina
« Reply #7 on: October 18, 2012, 10:06:49 pm »
I've built the MSI installer package following the Guru Geert instructions with SharpDevelop and Wix. It's very nice tools to work with, but ... SAME PROBLEM!!!!! "ERROR-MISSING". HOW COULD IT BE  :o?
Thanks.
« Reply #8 on: October 18, 2012, 10:16:32 pm »
As said before, you first need to determine the cause of the problem.
This could be
- COM interop registration of your dll
- Error in EA Addins reg key value
- Error in the code (like you forgot a required EA_ operation)
As long as you don't determine that there's not much we can do. :-/
zalbina
« Reply #9 on: October 21, 2012, 06:09:12 pm »
I see. I have not been trying the Excel yet, but I did try to deploy my dll using MSI package on different work stations in our network and it did work on some of them and did not on a rest. Could it be security issue or sort of it?
Paulus
« Reply #10 on: October 21, 2012, 08:21:44 pm »
... or perhaps your add-in is using other resources that are missing, things like .net framework, or certain ocx-es or 3d part dlls?  .... or ...: like Geert said, if you haven't got a clue use another method to access your add-in dll to rule out any issues that are not ea-related.
If Excel is not available on all workstations write a small vbscript in EA that uses createobject to load your assembly and run some method in it. If you have tested that in EA, run the script on other workstations in WSH or whatever scripting engine is available and check the err object for clues,
Paulus
« Last Edit: October 21, 2012, 08:25:09 pm by pmaessen »
zalbina
« Reply #11 on: October 23, 2012, 10:08:34 pm »
OK, I've added MyAddin dll from the References. After that I wrote in Excell VBA:
Dim abc as New MyAddin.MyAddinClass
abc.CheckDLL          'CheckDLL function calls for Message Box
I've got the message:
"ActiveX component can't create object".
So ...
Paulus
« Reply #12 on: October 24, 2012, 04:42:50 am »
... so that tells you the current problem is not related to EA but the deployment of the DLL itself.
Brute force: start with a version of your add-in with no dependencies (comment the code) and call again from VBA. If that works, start adding code/dependencies until the problem reappears. Then check the offending dependency. Note that even if the registry looks OK it may be incorrectly installed or be corrupt.
Paulus
zalbina
« Reply #13 on: October 24, 2012, 06:46:12 pm »
And if I created dll but don't see it in References it means the problem is with dll registration? How could it be? The VS 10 does it by itself and I also tried to register the dll with regasm. The registration was OK.
Paulus
« Reply #14 on: October 27, 2012, 12:55:42 am »
Maybe i misunderstand but my point is that you now have a simple testcase reproducing the error that doesn't require knowledge of EA to solve, just VS, COM and VBA.
So if you can't get an answer here (and this seems to be the case) there are plenty, and probably better, places where you can. Eventually your search might lead you back to EA  but for now that's not the case.
I suggested the brute-force method since that's what i usually do if i'm stuck like this.
best regards,
Paulus
« Last Edit: October 27, 2012, 12:57:22 am by pmaessen »
