Author Topic: ArchiMate: Associating a Data Object with a Relationship  (Read 6682 times)
bkone
  • Is this real?
« on: July 21, 2020, 05:19:52 pm »
Hello together,
I'd like to denote which Data Objects are transferred across a relationship in ArchiMate. I'm using EA 15.1 to create the model.
Example: Business Function A --Data Object--(Flow)--> Business Function B
I can connect the two Business Functions with a flow relationship, but I'm unable to create the additional association between the Data Object and the Flow relationship.
I already disabled already the "Strick Connector Syntax" in the preferences
Am I missing here something on how this could be done in EA?
Or is this not supported by EA? According to the standard of ArchiMate 3 this should be possible.
Best regards
Boris
« Last Edit: July 21, 2020, 05:38:11 pm by bkone »
Modesto Vega
Re: ArchiMate: Associating a Data Object with a Relationship
« Reply #1 on: July 21, 2020, 06:00:35 pm »
[SNIP]
Where about in the ArchiMate 3 standard says it is possible?
According to the table on https://pubs.opengroup.org/architecture/archimate3-doc/apdxb.html#_Toc10045480, it should be possible to create an access or an assocoation relationship between a Business Function and a Data Object but this is not what you are trying to do. You are creating a flow between 2 business functions and you want to attached/associate a data object to the flow.
I am not sure this is permitted in Archimate 3.
bkone
  • Is this real?
« Reply #2 on: July 21, 2020, 11:52:42 pm »
Hello Modesto Vega,
I was refering to chapter 5.2.4 "Association Relationship" in the AchiMate documents (https://pubs.opengroup.org/architecture/archimate31-doc/chap05.html#_Toc10045321) showing in the corresponding example what I like to achive.
Best regards
Boris
« Reply #3 on: July 22, 2020, 07:44:19 am »
This has been fixed for EA 15.2
Modesto Vega
« Reply #4 on: July 22, 2020, 06:02:20 pm »
Do you mean to say this would be fixed on EA 15/2? According to the Registered Users Section of the website. EA 15.2 is still in Beta.
[SNIP]
Thanks, much appreciated. I would always learn something new about ArchiMate.
