Author Topic: Custom Metamodel Diagram View  (Read 36176 times)
Jamo
« on: July 30, 2020, 12:20:38 am »
Hi all.
I've been trying to build a custom metamodel diagram view according to the documentation (https://sparxsystems.com/enterprise_architect_user_guide/14.0/modeling_tools/custommetamodelview.html) but I can't get it to work and I wonder why. Maybe I'm misunderstood or overlooked something.
My Model is built as follows
Model
-Package1
--(PackageDiagram) Package1
--<<profile>> MyProfile
---(PackageDiagram) MyProfile
---<<profile>> MyView
----(ClassDiagram) MyView
----<<view specification>> MyView
----<<stereotype>> SysML1.4::Block
----<<stereotype>> SysML1.4::Block Definition
MyView extends SysML1.4::Block Definition and exposes SysML1.4::Block as shown in the documentation in the last row of the table. Both stereotypes are abstract. I omitted the other elements, since they are just more extensions for elements in the toolbox.
I saved all diagrams and then exported the profile MyProfile via "Publish Package as UML Profile". Then I generated the MDG file and included the profile. I did not select any other functions like Toolboxes etc. When I import the MDG, I can find the technology in the MDG Technologies overview and I can also select it in the toolbox (Although no toolbox is defined for it, it just shows Common, Common Relationships, and Artifacts all folded in). When I try to create a new diagram, my custom view should appear under SysML 1.5, Block Definition as MyProfile::MyView, but it is not there.
I also tried out the instructions to "Create Custom Diagram Profiles" (https://www.sparxsystems.com/enterprise_architect_user_guide/15.1/modeling/custom_diagram_types.html, which seems really similar Custom Metamodel Diagram Views), but did not have any success with it either.
Any suggestions?
Jamo
Re: Custom Metamodel Diagram View
« Reply #1 on: July 30, 2020, 01:56:40 am »
Addition to the Custom Diagram Profile:
Managed to make it work after all, but have a follow-up question. In step 5 of the documentation it is described how to set the properties of the custom diagram. With the attribute "toolbox", you can select the default toolbox that is displayed when switching between different diagrams.
Setting this value to UML::Component or Extended::Construction correctly leads to the Class or Component toolboxes being displayed when selecting the diagram. However, this does not seem to work with "non-basic" toolboxes such as SysML 1.5::SysML 1.5 Internal Block. (All toolbox references where taken from the Find Toolbox Item tool)
I was wondering if this finding is correct and the normal user cannot set custom toolboxes for custom diagrams or if, once again, I'm just missing something.
Documentation: https://www.sparxsystems.com/enterprise_architect_user_guide/15.1/modeling/custom_diagram_types.html
« Reply #2 on: July 30, 2020, 07:21:45 am »
Both parts of the name you have used there are the "friendly" names. The actual id is SysML1.4::InternalBlock.
PS. The linked help includes the following hint to find the id to use for non-uml diagrams.
Note: If you do not know the fully qualified name of the diagram type you are extending, query the API to get the 'Metatype' field. In a Javascript console you can use:
?GetCurrentDiagram().MetaType
Jamo
« Reply #3 on: July 30, 2020, 08:04:27 pm »
Thanks for the clarification. A bit confusing, but it's good to know how to find the "true names" of diagrams.
But how do I find the true name of a toolbox? I couldn't find a corresponding console query.
Especially if I built the toolbox myself, I figured it should just be name I've given it. If I check the xml file for my toolbox I don't see any metatype attribute.
« Reply #4 on: July 31, 2020, 08:27:16 am »
There's no direct query for getting a toolbox name. In most circumstances you are referring to a toolbox you are creating.
Jamo
« Reply #5 on: July 31, 2020, 06:15:31 pm »
Indeed. While going through all the different possibilities to refer to a custom toolbox, I figured out that it was in fact just the toolbox name I had to refer to, without the name of the profile or the MDG technology.
So instead of MyProfile::MyToolbox, the string MyToolbox is sufficient. That's a bit confusing since you cannot refer to the UML Component toolbox with Component but have to use UML::Component.
« Reply #6 on: August 03, 2020, 08:12:44 am »
Within your technology you are already in your namespace. UML isn't the default namespace.
Plonka
« Reply #7 on: February 27, 2025, 02:58:26 am »
Can someone please explain how this works?
I opend a diagram and then went to Specialize -> Tools -> JavaScript and entered the command.
Result was: GetCurrentDiagram(...) is undefined.
I think I need to define which Diagram I want the Metatype from but I don't know how...
Takeshi K
    • Sparx Systems Japan
« Reply #8 on: February 27, 2025, 09:36:19 am »
The reason of the error is that the current diagram is 'null' because the JavaScript console is active (the 'current'). I guess that there is no way to run the command without activating the JavaScript console tab.
If you enter ?GetCurrentDiagram(123).MetaType (which 123 should be the Diagram ID of the target diagram) to the console command area, the console returns the value of the MetaType correctly.
t-kouno
Plonka
« Reply #9 on: February 27, 2025, 08:03:31 pm »
Thanks Takeshi,
I found this Link: https://sparxsystems.com/enterprise_architect_user_guide/17.0/add-ins___scripting/javascrip_console_the.html
The commands are working for a SysML Block Element I selected in the tree
currentElement = Repository.GetTreeSelectedObject()
Session.Output("Selected ElementID: "+currentElement.ElementID)
->Selected ElementID: 12
But this does not work for diagrams I select in the browser tree.
And I can not find the diagram ID. Only the GUID but this is the wrong one.
Maybe you know where I am wrong or what I am misssing.
Kind regards
Plonka
Elpis
  • Make MDA/MBSE vital.
« Reply #10 on: February 28, 2025, 12:20:42 am »
If you are referring to *diagram* selected in the Browser, this works in Javascript console:
currentDiagram = Repository.GetTreeSelectedObject()
? currentDiagram.DiagramID +"; "+currentDiagram.MetaType +"; "+ currentDiagram.Name
Plonka
« Reply #11 on: February 28, 2025, 07:10:37 pm »
Ah thanks!
That makes sense.
One problem less on my list.
