Author Topic: DBBuilder – need indication that Import/Synchronise has completed  (Read 6284 times)
The Database Builder (DBBuilder - DBB) is proving quite useful for our purposes.  But there is one part of the UI where things could be improved (surprise, surprise).   ;)
We need an indication that the operation that we've asked DBB to perform has completed.  It's not just a cosmetic issue.  If you don't know it's completed, you are tempted (and most often succumb) to re-running the operation.  Unfortunately, due to a suspect defect in the process, re-running the same operation is NOT non-destructive.  It may, for example, create spurious duplicate columns etc.
My personal preference is that the UI "kill two birds with one stone".   On completion of the operation, a dialog would appear saying that the operation has completed and as an optional button on the dialog, ask if we'd like the "generate differences" operation to be re-run (to indicate how well the previous operation has performed).
Thoughts?
Re: DBBuilder – need indication that Import/Synchronise has completed
« Reply #1 on: August 17, 2020, 05:42:05 pm »
Yes, please.
I've been doing the same thing, trying to synchronize my model with the physical database after every release.
More often then not I have to synchronize at least twice before the two models are really in synch.
It is indeed hard to see if the operation has completed (I sometimes check the task manager to be sure)
Graham_Moir
« Reply #2 on: August 18, 2020, 01:13:12 am »
+1
« Reply #3 on: September 09, 2020, 09:48:31 am »
+1 too
« Reply #4 on: September 09, 2020, 01:18:15 pm »
+1  (I've mentioned this on other posts)
Modesto Vega
« Reply #5 on: September 09, 2020, 05:55:36 pm »
+1
