Author Topic: components and artifacts  (Read 8378 times)
ngong
« on: August 23, 2020, 12:25:54 am »
For a component, what is the best way to enter and show an artifact (by which the component is deployed in a node) like in Figure 11.42 Optional "white-box" representation of a Component in Unified Modeling Language 2.5.1?
I can enter a filename in Files but I was not able to make it visible on the component diagram.
Rolf
Richard Freggi
Re: components and artifacts
« Reply #1 on: August 23, 2020, 12:20:08 pm »
My understanding is that artifacts should be displayed in Nodes (deployment diagram), not in Components.
ngong
« Reply #2 on: August 23, 2020, 02:25:51 pm »
That is my understanding too, Richard, if by in you mean owns. A component does not own an artifact. An artifact still exists even if a related component may not, any longer.
However, a component may be related to an artifact, e.g. a Sort component, coded as a singleton class Sort.java,  could be hosted as a service in binary in a file-artifact named UtilityServices.jar. UtilityServices.jar is created to get loaded (deployed) on a Server node.  We may state after loading, the Server owns that artifact. Our UML standard recommends to capture that relationship as one value - the filename - in an artifacts compartment of the component UtilityServices.jar.
Please have a look at the link  Figure 11.42 Optional "white-box" representation of a Component from UML 2.5.1 standard.
My problem with EA 15.1 is: How to get an artifacts compartment for a component? Is the artifacts compartment simply missing? As a work-around one could introduce a stereotype defining a certain tag. Or:  Would it be possible to add a custom compartment to an element of type Component? How?
Any idea?
Rolf
Richard Freggi
« Reply #3 on: August 24, 2020, 01:44:44 am »
Hi Ngong, by "displayed in" I mean "displayed in".
« Reply #4 on: August 24, 2020, 04:36:34 am »
Tautology?
Modesto Vega
« Reply #5 on: August 24, 2020, 06:13:01 pm »
Section 11.6.4 Notation of the UML 2.5.1 specification - please see https://www.omg.org/spec/UML/2.5.1/PDF, clearly states that this should be possible.
"Additional optional compartments “realizations” and “artifacts” may be used to list the realizing Classifiers (Classifiers reached by following the realization property) and manifesting Artifacts (Artifacts that manifest this component – see 19.3)."
The figure ngong quoted, Figure 11.42, shows an example of how to do this.
I cannot find a way to get Sparx to show any of the "whitebox" optional compartments, but perhaps I don't know how.
ngong
« Reply #6 on: August 25, 2020, 02:43:45 am »
Thank you for commenting Modesto and Richard.
@Richard: Sure, I know what "displayed in" means, Richard. My problem was to map your wording about the relation between a node and an artifact to something I can find in UML standard. "Displayed in" is not listed as a known. relation. Even, I am not sure if "owns" is something defined there. What I mean is, that in EA the project browser shows a node and if you open the tree, it shows the artifact. I think, "owns" is the right wording about it. A diagram is just a window into the model. The model is listed in the project browser.
@Modesto: thank you, your comment encourages me to find a workaround in my current project.
Rolf
Rolf
« Reply #7 on: August 25, 2020, 03:46:13 am »
You can write a shape script using
shape ChildElement. Of course you need to stereotype your component.
