Author Topic: Trying to access EA Project from outside the EA Process with ("EA.App")  (Read 16752 times)
sarathipriyan
Hi Geert and Uffe,
Using C# code we’re trying to access EA Project from outside the EA Process with something like GetActiveObject("EA.App") object. Is there any code sample (c#) that I use? We have a Enterprise Architect v15.2.1554(Trial Edition Free 30 day unlimited) and I'm using VS2019 community.
can you please share the sample c# code for access (create and get) EA Project from outside the EA .
Re: Trying to access EA Project from outside the EA Process with ("EA.App")
« Reply #1 on: September 30, 2020, 10:21:47 pm »
This is the code I use to connect to the running instance on my model wrapper class https://github.com/GeertBellekens/Enterprise-Architect-Add-in-Framework/blob/master/EAAddinFramework/EAWrappers/Model.cs
        public Model()
            object obj = Marshal.GetActiveObject("EA.App");
            global::EA.App eaApp = obj as global::EA.App;
            this.initialize(eaApp.Repository);
this code (vbscript) creates a  new EA instance
dim repository
set repository = CreateObject("EA.Repository")
sarathipriyan
« Reply #2 on: October 01, 2020, 07:44:10 pm »
        public Model()
dim repository
Thanks for the update. I will check and update you
sarathipriyan
« Reply #3 on: October 01, 2020, 07:48:43 pm »
Hi Geert,
here's a copy of the code I'm using to connect with the EA repo externally.
static class Program
        /// <summary>
        /// The main entry point for the application.
        /// </summary>
        private static global::EA.Repository _wrappedModel;
        [STAThread]
        static void Main()
            Model();
            Console.WriteLine("Hooked upto repository");
            DumpModel();
        static public  void DumpModel()
            for(short i=0; i < _wrappedModel.Models.Count; i ++)
                DumpPackage("", (EA.Package)_wrappedModel.Models.GetAt(i));
        static public  void DumpPackage(string s, EA.Package package)
            Console.WriteLine("Package Name = " + package.Name);
            DumpElements(s, package);
        static public void DumpElements(string s, EA.Package package)
            for (short j = 0 ; j  < package.Elements.Count; j ++)
                EA.Element element = (EA.Element)package.Elements.GetAt(j);
                Console.WriteLine(":: " + element.Name);
        static public void Model()
        static public void initialize(global::EA.Repository eaRepository)
            _wrappedModel = eaRepository;
I have also created a project, Requirement, package, and elements from EA console.
but I'm not able to get the elements externally. The count is zero(package.Elements.Count;)
how do I get the elements from EA?
« Last Edit: October 01, 2020, 09:09:44 pm by sarathipriyan »
« Reply #4 on: October 01, 2020, 08:00:24 pm »
I don't see the code you are using to start EA, nor the code you are using to open a model.
But more importantly, you are only dumping elements, not packages.
Usually there are no elements directly under the root packages, only packages.
sarathipriyan
« Reply #5 on: October 01, 2020, 10:16:29 pm »
Yes you're right in that code first we are opening the package and than we print the elements inside the package we wrote.
About opening the model, Sorry I thought object obj = Marshal.GetActiveObject("EA.App") would open the model. Can you suggest which call we need to use to open a model.
« Reply #6 on: October 01, 2020, 10:34:01 pm »
Marshal.GetActiveObject("EA.App") gets you the running instance of EA, with or without model loaded.
If you want to load another model, use Repository.OpenFile or Repository.OpenFile2
sarathipriyan
« Reply #7 on: October 07, 2020, 01:43:17 am »
Thank you for your suggestions Geert, now I'm able to create and modify packages and elements. I can see the package and elements in EA dashboard. Is there a quick way to visualize that relationship as model diagram in EA?
I  have tried to use package diagram to view the elements but it's not working.
