Author Topic: PCS Management client ssl connection  (Read 32207 times)
Typia
« on: November 19, 2020, 01:31:22 am »
I would like to manage PCS with a dedicated PC with client installed on it, is it possible to secure the connection with SSL ?
I'd like to use the client and not webconfig.
Many thanks
Prolaborate Support
  • Prolab Moderator
    • Visit us
Re: PCS Management client ssl connection
« Reply #1 on: December 05, 2020, 04:24:42 pm »
Hi, Do you want to connect to EA models through PCS HTTPS connection?
If yes, please refer to Section 3.5 this guide
Typia
« Reply #2 on: January 14, 2021, 03:32:22 am »
thanks for your answer,
no, I want to connect Pro Cloud Config Client (currently TCP 803) through secure connection.
Aaron B
« Reply #3 on: January 19, 2021, 10:55:37 am »
Hi Typia,
There is no way to connect the Pro Cloud Config Client via https that I'm aware of. It's only intended to be accessed this way on a private network.
The description from the config file:
# The SERVER_PORT setting defines the TCP Port that the
# Configuration Client and the ISAPI module will communicate on.
# It is NOT recommended to expose this port outside of
# your private network.
SERVER_PORT=803
If you need to manage the configuration over https then I'd suggest using WebConfig instead.
