Author Topic: XSD: XML Schema file  (Read 8271 times)
zalbina
« on: December 18, 2012, 09:31:17 pm »
I've seen bunch of questions are related to this topic. In my case I need to produce XML Schema file from regular UML. I was looking for some Code Generation Templates for XML Schema which I can adopt for our needs but I did not find it. If such a template does not exist how can I modify the standard ouput of the XML Schema Generation?
Thanks.
Andreas1975
Re: XSD: XML Schema file
« Reply #1 on: January 08, 2013, 01:12:56 am »
Hi.
If I understood everything correct, the way to do it is a 2-step generation:
UML Model ---> XML Schema Model --> XSD-Files (XML Schema)
The first step you can modify yourself (From UML Model to XML Schema Model) using the Transformation Templates.
Unfortunately you can't modify the actual XML-Schema generation.
However,
Since you can modify the first step, you have at least some control of how generation of the final XML Schema should be like.
regards
Andreas
