Author Topic: Linking notes to project glossary  (Read 4877 times)
mrblack12
« on: January 08, 2013, 02:30:29 am »
I want to create new glossary definitions from some of the text items in a notes window. The EA use manual says you can do this by right-clicking on a text item and then choosing the glossary, but my context menu doesn't have that option (just the standard Undo, Cut, Copy, Paste, Select All).
Is this something I can change by changing a setting or is this implemented in versions from 7.5 up, so I should upgrade? :-[
Re: Linking notes to project glossary
« Reply #1 on: January 08, 2013, 02:55:06 am »
It might be a View/Workspaces/Commands issue. Check that the full command set is on.
P.S.: Reading again it appears you are pre-7.5?
« Last Edit: January 08, 2013, 02:56:37 am by qwerty »
« Reply #2 on: January 08, 2013, 08:43:09 am »
It was added in version 8.
