Author Topic: Retrieve nested elements from an element and display name with parent name  (Read 23811 times)
priombiswas89
I am trying to retrieve the embedded/nested elements from an element and display the names of embedded elements with parent element.
Below is the image of my model:
https://ibb.co/XyHT8z7
The format I want to  achieve for list of the states are as follows:
off
Boot
Wait for HK
uPError
Run/AliveQuery
Run/AliveQuery/State1
Run/WaitAliveResponse
Run/WaitAliveResponse/State2
Run/WaitAliveResponse/State2/State3
The code so far I have tried is as follows:
case EA.ObjectType.otDiagram:
                            diag = Rep.GetContextObject();
                            diagramElementsObj.refDiagramId = diag.DiagramGUID;
                            diagramElementsObj.refDiagramName = diag.Name;
                            diagramElementsObj.states = new List<State>();
                            diagramElementsObj.transitions = new HashSet<Transition>();
                            foreach (EA.DiagramObject diagramObj in diag.DiagramObjects)
                                int diagramId = diagramObj.DiagramID;
                                EA.Diagram diagram = Rep.GetDiagramByID(diagramId);
                                int elementId = diagramObj.ElementID;
                                EA.Element element = Rep.GetElementByID(elementId);
                                #region For object creation
                                if (!string.IsNullOrEmpty(element.Name))
                                    if (element.Type.Contains("StateNode"))
                                        diagramElementsObj.initialState = element.Name;
                                    else
                                        State stateObj = new State();
                                        stateObj.name = element.Name;
                                        stateObj.operations = new List<Operation>();
                                        diagramElementsObj.states.Add(stateObj);
                                        // To get embedded elements
                                        if (element.Elements.Count > 0)
                                            for (short ip = 0; ip < element.Elements.Count; ip++)
                                                int parentId = 0;
                                                EA.Element child = (EA.Element)element.Elements.GetAt(ip);
                                                parentId = child.ParentID;
                                                EA.Element parent = Rep.GetElementByID(parentId);
                                                stateObj.name = $"{parent.Name}/{child.Name}";
                                                GetEmbeddedElement(child);
                                        if (element.Methods.Count > 0)
                                            // To get embedded operations and their corresponding action type, eg. entry, exit, do for state diagram
                                            foreach (EA.Method meth in element.Methods)
                                                Operation operationObj = new Operation();
                                                operationObj.name = meth.Name;
                                                operationObj.type = meth.ReturnType;
                                                stateObj.operations.Add(operationObj);
                                #endregion
                                foreach (EA.Connector item in element.Connectors)
                                    bool isOld = false;
                                    int clientId = item.ClientID;
                                    int supplierId = item.SupplierID;
                                    EA.Element clientElement = Rep.GetElementByID(clientId);
                                    EA.Element supplierElement = Rep.GetElementByID(supplierId);
                                    Transition transitionObj = new Transition();
                                    transitionObj.from = clientElement.Name;
                                    transitionObj.to = supplierElement.Name;
                                    transitionObj.trigger = item.TransitionEvent;
                                    string effectsList = item.TransitionAction;
                                    effectsList = effectsList.ReplaceAll(charsToReplace, ',');
                                    effectsList = Utilities.TruncateCommas(effectsList);
                                    transitionObj.effects = $"[{effectsList}]";
                                    foreach (var transItem in diagramElementsObj.transitions)
                                        if (transItem.from.Equals(transitionObj.from) && transItem.to.Equals(transitionObj.to))
                                            isOld = true;
                                            break;
                                    if (!isOld)
                                        diagramElementsObj.transitions.Add(transitionObj);
                                    #endregion
                            break;
Below is the recursive method:
private void GetEmbeddedElement(EA.Element element)
            EA.Collection elements = element.Elements;
            for (short ip = 0; ip < elements.Count; ip++)
                EA.Element child = (EA.Element)elements.GetAt(ip);
The output I am getting as follows:
off
Boot
Wait for HK
uPError
AliveQuery/State1
Any kind of help will be much appreciated.
« Last Edit: January 08, 2021, 01:09:10 am by priombiswas89 »
No proof reading your code, but embedded has different meanings. You seem to expect that diagram embedded is the same as element embedded. That's not the case. On a diagram you can graphically embed anything. So maybe you are mislead by the graphics. Look into the browser to see the real element embedding.
priombiswas89
Please refer to the following image:
https://ibb.co/5nJNydw
This actually should be nested element.
You can't see that on a diagram, things get un-nested sometimes.
How does it look in the project browser? That is what shows the real nesting.
priombiswas89
Yes, I am trying to achieve it from referring to project browser. But still haven't been able to get the desired output.
It "looks" like these are the same, but you can only tell by actually issuing Alt-G on each to see where it lands in the browser.
priombiswas89
I know and I can see the tree, somehow I am struggling to print the tree structure as mentioned in my original post. Any kind of help will be much appreciated.
Well, break it down to something that can be looked at. That pile of code is too much (for me).
priombiswas89
Below is the snippet for getting element:
        int parentId = 0;
        GetEmbeddedElement(child); // called the recursive method
below is the recursive method:
« Last Edit: January 07, 2021, 08:14:40 am by priombiswas89 »
Well, and what would you expect? That operation recurses and returns without anything.
priombiswas89
That's why actually I have posted the whole code above. I want to achieve below
Run/AliveQuery
the reference image is as follows:
If you want the full path, you'll have to pass the part you already did to the function. Otherwise you won't be able to get more then parent/child
And you'll have to do something in your function, like actually print the full path
PS. this part is completely superfluous as you already have the parent element, the variable element
You are actually iterating the parent's children, and from each child you retrieve it's parent again.
priombiswas89
I have modified the code as below:
                                if (element.Elements.Count == 0)
                                // To get nested elements
                                    string parent = element.Name;
                                        stateObj.name= $"{parent}/{child.Name}";
and got the following output:
- name: off
- name: Boot
- name: Wait for HK
- name: Run/WaitAliveResponse
- name: AliveQuery/State1
- name: WaitAliveResponse/State2
- name: uPError
- name: Shutdown
- name: State1
- name: State2/State3
- name: State3
I am not sure but do I need to print it inside the recursive GetEmbeddedElement method?
I'm not sure what you are trying to achieve with the GetEmbeddedElement method.
It' doesn't do anything.
priombiswas89
I am trying to get the path by calling this method. The path can be any level deep. As nesting can be done till any level, I need to do a recursion right? Or is there any api method that can return the path in Enterprise Architect?
