Author Topic: API to set the diagram "Freeze Visible" property?  (Read 8191 times)
adepreter
« on: May 07, 2021, 08:47:55 pm »
Does anyone know what is the API to set the diagram "Freeze Visible" property?
Cheers,
Alain
Re: API to set the diagram "Freeze Visible" property?
« Reply #1 on: May 07, 2021, 09:23:48 pm »
Where would I find that property in the GUI?
adepreter
« Reply #2 on: May 07, 2021, 10:30:13 pm »
On an opened diagram
=> Properties window => Connectors group => Freeze Visible
Then the issue is how to change this useful value using the API?
« Reply #3 on: May 07, 2021, 11:25:20 pm »
I'm guessing its going to be somewhere in either PDATA or StyleEx
The best way to figure it out is to get these values, change the property, and then compare.
philchudley
« Reply #4 on: May 08, 2021, 12:27:49 am »
After a bit of experimentation the styleex is
DLKO=1;
This can be added manually to the stylexx attribute for the diagram metaclass in the MDG
I did find the order seemed to matter, so for my MDG I have:
HideConnStereotype=0;DLKO=1;FTV=1;ETV=1;
Being HideConnectorSterotypes = false    FreezeVisible = true     Filter to Version = true       New to Version is true
Phil
Models are great!
adepreter
« Reply #5 on: May 08, 2021, 03:30:14 am »
You are all amazing!
THANK YOU :-)
