Author Topic: Connector behind Label/Element  (Read 5843 times)
Reawel
« on: August 10, 2021, 03:55:48 am »
Hey Guys,
in this Post (https://www.sparxsystems.com/forums/smf/index.php/topic,29998.msg219578.html#msg219578) it was mentioned that it is not possible to set the Connector behind an Element. But the post ist more than 10 years old, so i just wanted to ask if there is an option to do that in the meantime. We have a Shape with the Name label directly above the Element and the connectors go through the label. Or maybe you have another solution.
Thanks!
Reawel
Re: Connector behind Label/Element
« Reply #1 on: August 10, 2021, 08:12:45 am »
Hey Guys,
Thanks!
Reawel
Hi Reawel,
No, you can't directly suppress that behaviour.  You can change the line style and the route of the line. Or you can suppress a segment of the line (once you use custom line style), but that can be difficult to follow.  Use the connector context menu to investigate the possibilities.
« Reply #2 on: August 10, 2021, 08:16:44 am »
Brings back memories (one of my former lifes as "beginner"). And that nothing has changed :-/
No. It was wished that is should be possible to do that, but there were reasons (and in that case I think they were for good). Either you  root the connectors around the label or you position the label elsewhere (since it's a label that should be possible).
Before you ask: to add a picture you need to place it on a public server and use the link,
« Reply #3 on: August 10, 2021, 09:51:23 am »
q,
This thread is about labels v15.2 – Arc labels do/don’t override line
This one (as I understand Reawel) is about elements.  In rectangular mode, there is NO label (much to our chagrin).  The text is in a fixed position and orientation.
« Reply #4 on: August 10, 2021, 05:00:18 pm »
That was why I mentioned the pictures. The awkward way to attach pictures to those threads here makes it difficult to explain issues.
Reawel
« Reply #5 on: August 10, 2021, 05:34:24 pm »
Okay, yeah i already thought that this is not possible, but i just wanted to give it a shot and ask.
But thanks! :) We will just move the labels
Reawel
