Author Topic: 15.2 and SQL error  (Read 11564 times)
ChrisMW
15.2 and SQL error
« on: September 16, 2021, 12:14:08 am »
Since 15.2 I'm getting errors when I open a repo in PostgreSQL, where 15.1 had no issue. Now I get a box saying "SQL Error at updating Reference Data" and not quite sure where to look. The PostgreSQL server runs on the host, Mint 20.1, so could have been updated, 15.2 I installed, but haven't used much of late, my employer has provided a license on their laptop, so I've not been using it a lot. I do remember it was working perfectly. So any suggestions on what to check first would be appreciated. I did open de ODBC manager, and the test connection is fine. From a PgAdmin view, it looks good, but it's not.
Re: 15.2 and SQL error
« Reply #1 on: September 16, 2021, 12:22:58 am »
Look into %APPDATA% - some Sparx folder - dberror.txt. That should give the failing query (eventually). Not that it would help you, but maybe someone got an idea if you post it.
ChrisMW
« Reply #2 on: September 16, 2021, 07:45:17 am »
Good tip, but the last entry is more than a year old. Oddly enough I tried opening a database I hadn't touched in a while, and I got the error, but the repo  still opened. Since then, the other also open but the error is still shown.
I am wondering if it has something to do with the reference  data that you import/export? But in all my years with EA, this one is new to me. Based on the efforts so far, I an thinking it might not be related to the DBMS, but what is it then?
« Reply #3 on: September 16, 2021, 08:15:44 am »
You'd best mail Sparx support for that. Without looking into your config it's hard to tell.
ChrisMW
« Reply #4 on: October 01, 2021, 06:21:37 pm »
So I did and it turns out that it was an add-on, in my case the RAMI toolbox, which I was intending to use for some Industry 4.0 work, but never did. So I simply removed that add-on and it was solved. No more errors....
