Author Topic: Where has 'make this diagram my default' gone in v16?  (Read 33782 times)
Ian Mitchell
« on: October 22, 2021, 08:51:20 pm »
I only just worked out where it was in V15, and now it's moved again.
...and customers wonder why there is no 'Introduction to EA' course, when the UI changes every release. Sigh.
www.eaDocX.com
www.theartfulmodeller.com
wivel
  • Driven by Models
Ian Mitchell
Re: Where has 'make this diagram my default' gone in v16?
« Reply #2 on: October 25, 2021, 09:28:26 pm »
Ah- I found that option as well, but een when I have the diagram open, and selected in the PB, the options are still disabled.
Using a single-user EAPX repository.
Anyone made this work in this environment ?
www.eaDocX.com
wivel
  • Driven by Models
« Reply #3 on: October 26, 2021, 02:31:50 am »
Hi Ian
You are right. It does not work. Tried it on both an EAPX and an MSSQL model in both EA 16 32 abd 64 bits, with no luck. The option keeps being disabled.
Henrik
« Reply #4 on: October 26, 2021, 06:12:03 am »
Works for me, but I'm using security. I can imagine that is a prerequisite.
It doesn't work for me on a new model without security enabled.
Ian Mitchell
« Reply #5 on: October 26, 2021, 06:57:09 pm »
In V15 EA didn't care if you had security enabled.
I think this is a bug. I'll report it.
www.eaDocX.com
wivel
  • Driven by Models
« Reply #6 on: October 26, 2021, 08:30:10 pm »
Or it could have been a bug in EA 15.x. When you think of it, how would EA know which user to show which diagram for if you do not have user security enabled?
Henrik
« Reply #7 on: October 26, 2021, 09:04:10 pm »
Henrik
I think it used to use your windows user name.
wivel
  • Driven by Models
« Reply #8 on: October 26, 2021, 10:11:12 pm »
Makes sense.
Henrik
« Reply #9 on: October 27, 2021, 08:35:46 am »
If the option you were thinking of didn't need security then you were setting the model default diagram. Start > Collaborate > Model Home
The author field is filled with the Windows user name if security isn't enabled, but the user diagram option has always been saved against a user id, which won't exist if you're not using security.
Ian Mitchell
« Reply #10 on: October 27, 2021, 09:51:29 pm »
Reply from Sparx to bug report:
That's correct, to avail these features you need to have Security enabled.
https://sparxsystems.com/enterprise_architect_user_guide/16.0/modeling/usr_model-default_diags.html
Which is true - it only works with security enabled.
But it worked fine in V15 with no security. So why the change? I have asked @Sparx.
So what's this - a v15 bug which got fixed, or a V15 feature which got disabled?
Not sure I care much - please can we have this back....
www.eaDocX.com
wivel
  • Driven by Models
« Reply #11 on: October 27, 2021, 11:28:24 pm »
Hi Eve
The option we are looking is to set the default diagram for the current user, not for all users of the model. As Ian pointed out, it worked fine in EA 15.x without security enabled. The question now is whether it is a bug in EA 16 or a bug in EA 15.x that has now been fixed.
Henrik
« Reply #12 on: October 28, 2021, 08:44:37 am »
Just in case my memory was failing me I just tested 15.0, 15.1 and 15.2. None of them allowed setting a per user diagram without security enabled.
As I said. That option has always been stored using the id (guid) of a security user. Even if there was a bug that enabled it in 15, it could never have loaded a diagram from that.
Is it possible that you actually had security on with 'Accept Windows Authentication' enabled?
