Author Topic: Adding existing elements to a diagram  (Read 18358 times)
lopata
« on: March 29, 2004, 05:36:29 am »
Hello folks!
I would like to perform a simple task. I have a package with elements which I'd like to copy to a newly created or an existing diagram.
First I thought this would be a simple task - the documentation includes an example where a similiar task is performed, I'm quoting:
Add and Manage Diagrams
public Object
''an example of how to create a diagram and add an element to it
''note the optional use of element rectangle setting using
''left,right,top and bottom dimensions in AddNew call
Sub DiagramLifeCycle
    Dim diagram as object
    Dim v as object
    Dim o as object
    Dim package as object
    Dim idx as Integer
    Dim idx2 as integer
    package = m_Repository.GetPackageByID(5)
    diagram = package.Diagrams.AddNew("Logical Diagram","Logical")
    If not diagram.Update Then
        Console.WriteLine(diagram.GetLastError)
    End if
    diagram.Notes = "Hello there this is a test"
    diagram.update()
    o = package.Elements.AddNew("ReferenceType","Class")
    o.Update
    '' add element to diagram - supply optional rectangle co-ordinates
    v = diagram.DiagramObjects.AddNew("l=200;r=400;t=200;b=600;","")
    v.ElementID = o.ElementID
    v.Update
    Console.WriteLine(diagram.DiagramID)
End Sub
-- end of example
This looks very promising, however to my surprise this example is simply wrong! The attribute ElementID of the Element interface is read-only, which means that the assigment from the example will not work!
So, my question is, how to add an existing element from a package to a diagram? Do I have to deepcopy all the writeable attributes and collections from the package-element to a newly cerated diagram-element? Would it even work this way?
Thanks for help.
Hynek Cihlar
A && L Soft
www.alsoft.cz
www.flexlanguage.com
Hynek Cihlar
A
 L Soft
www.alsoft.cz
Bruno.Cossi
Re: Adding existing elements to a diagram
« Reply #1 on: March 29, 2004, 05:40:28 am »
the example actually works. For diagram objects, ElementID is not read only.
Bruno
« Last Edit: March 29, 2004, 05:41:46 am by Bruno.Cossi »
lopata
« Reply #2 on: March 29, 2004, 09:59:17 pm »
I see! I was casting it to an Element!
Thanks for help.
Hynek Cihlar
A && L Soft www.alsoft.cz www.flexlanguage.com
Hynek Cihlar
A
 L Soft
www.alsoft.cz
Bruno.Cossi
« Reply #3 on: March 29, 2004, 10:01:47 pm »
Not a problem :-) It gets a little confusing.
Bruno
