Author Topic: Enable SysML 1.3 when only 1.5 is available  (Read 8580 times)
oiwuernnslkdjf
« on: December 16, 2021, 07:37:41 pm »
Hello there,
we use SysML 1.3 in our models. I only seem to have SysML 1.5 on my machine (Toolbox Visibility) which is not not fully compatible with SysML 1.3. How to enable SysML 1.3?
Thanks!
Re: Enable SysML 1.3 when only 1.5 is available
« Reply #1 on: December 16, 2021, 08:12:04 pm »
You have to create your own perspective to do that.
Guillaume
    • www.umlchannel.com
« Reply #2 on: December 21, 2021, 01:23:06 am »
What EA edition do you use ?
I think that since EA 15.2, the Corporate edition supports SysML 1.5 (but not previous versions). Until then, SysML was only available in the Unified and Ultimate editions.
If you use SysML 1.3, it'll only be available with a Unified or Ultimate edition.
Guillaume
Guillaume
« Reply #3 on: December 21, 2021, 07:55:01 am »
In EA 16, assuming you have the right edition, if you select the perspective Systems Engineering > SysML you get access to SysML 1.5 only, but if you select the perspective Systems Engineering > All Systems Engineering you get access to SysML 1.1, 1.2 and 1.3 as well. You may still want to consider Geert's suggestion and create your own custom perspective though (the only way to access the earlier versions in EA 15).
Fefceac
« Reply #4 on: January 07, 2022, 10:08:31 pm »
Hi, as Geert recommended you need to create a custom perspective to display older version in ea 15. See the userguid in this sections.
https://sparxsystems.com/enterprise_architect_user_guide/14.0/user_interface/techno_sets.html
https://sparxsystems.com/enterprise_architect_user_guide/14.0/user_interface/what_perspectives.html
